XTR8CK Sirius Satellite Plug & Play Radio Receiver and Vehicle Kit
Just got this for christmas:
http://www.xactcommunication.com/Rep...e-Kit-104.html
signed up for the service this morning and so far, it is awesome
I need to run the antenna wire so i can hook it up in my truck. My quesiton is, have most people setup such units by hooking up a wire that plugs into a headphone jack into their receiver? Or should I do it some other way?
this unit also has an fm transmitter I think, but i'd rather hardwire it.
thanks.
thanks.
Here's my experience with a 3rd gen 4runr:
I had a friend's XM for a little while, which didn't have a transmitter feature. I used a casette adapter in my head unit, with the wire coming out of the cassette 'mouth' and going straight down and tucking into & under the trim bezel. You could only see about an inch of wire, where it ran between the 2 & 3 presets. When I wanted to listen to XM, I'd just hit 'tape'. It worked very well. That would be my first recomendation as it sounded great, was easy, and was relatively stealthy - as long as you have the stock headunit with the cassette deck and don't mind pulling the top of the bezel from the dash just enough to stuff the wires in there.
Then I had to give the XM back to my friend. I just got the Sirius One. I've mounted it to the sun visor and hard-wired the power into the map-light console. I'm using the transmitter feature and it sounds great -- at least as good as a strong FM station. (I don't have sat radio so much for the sound quality, as for the content.)
At first I struggled to get a clear signal though until I tried this... I searched for a frequency where there was no signal on the adjacent frequencies. In Baltimore, it was hard to find three consecutive frequencies with no signal - for the most part, every other frequency had something. I finally found one where the upper frequency had a very weak signal and programmed that into preset #1. It works great. If I were to do a long road trip up to New York or something like that though, I'd probably just use a casette adapter and temporarily let it dangle. If the transmitter should at some point stop working so well, I'll just go back to the cassette method I used with the old XM unit.
Hope it helps.
Hope it helps.
thanks for the feedback
i think im gonna try to hardwire both power and input... i figure, if i can hardwire it so i get a cord coming out of my aux that plugs into a headphone jack, i can run anything from an ipod to the sirius tuner....
thanks again.
thanks again.
09-04-2015 09:27 AM
88runnergomas
07-09-2015 01:12 PM
