YotaTech Forums
-   Vehicle Audio & Home Entertainment (https://www.yotatech.com/forums/f96/)
-   -   Sub help (https://www.yotatech.com/forums/f96/sub-help-200680/)
BackGateYota92 Jan 5, 2010 04:44 PM
Sub help
Hey i have a Rockford Fosgate 12" P3 with a 1000 watt sony amp. When the sub hits it looks like its barely moving at all compared to my old sub. Does this mean the sub is underpowered and will it damage the sub at all? Thanks for the help
milehigheric Jan 12, 2010 02:06 AM
Did you install it yourself, have you set the gains correctly, is it wired correctly. No one can come to a positive conclusion with that amount of info.
Im more than willing to help you out, just need some info...
NYChopshop Jan 12, 2010 02:58 PM
amp model number would help, so would more info on the sub. From what I can see, there are shallow mount and non shallow mount, and different dual voice coil impedance in other models, all in 12" P3. How is it wired? How is the sub mounted? Do you have a capacitor? MORE INFO NEEDED!
