Speaker Problem
Hey,
i just upgraded the speakers in the rear to 6x9's... one sounds great... the other is weak. i tried getting a new little rear amp thing in the box. and it still didn't work right, the speaker is fine. its just the right side that sounds bad... if i plug things into the left, it works fine... other than the old amp... any ideas? please |
HELP PLEASE... i'm ripping out my hair
The stock rear amps don't like to work with aftermarket headunits.
it worked fine with the 5.5's i had in there
upgrade to a higher gauge wire . youll love it , only run the lengths you need and remove excess power is lost through distance.
X2 new wires i had the same problem and new wires cleared it up alright but then a ran a 200watt amp to them and they sound even better
i jerry rigged the setup to the one rear amp that worked. that will do until i get new wires or an amp. thanks for your help.
with the new wires are you still using the little box amps? or do you just get rid of them all together? |
