YotaTech Forums
-   Vehicle Audio & Home Entertainment (https://www.yotatech.com/forums/f96/)
-   -   radio problems! (https://www.yotatech.com/forums/f96/radio-problems-235197/)
jordan88runner May 13, 2011 03:03 PM
radio problems!
alright today i was wiring up my winch and mounting it up on my bumper, and i hook up the remote and bring it in real nice and tight and all of the sudden my radio goes out! idk what it could be, i have already checked all of my fuses and they are good and i pulled out my radio the fuse on the back is still good and there are no wires that look fried up either! anyone ever have this happen? or got any suggestions on what it might be??
thanks, Jordan
snowcrash Jun 14, 2011 07:58 AM
if you have the factory plug for the radio, you could put hot to the acc and 12 volt hot wire and then ground the radio and it should come on then. If it does, then there is a wiring issue. I'm sure there is a fuse somewhere you haven't found. Also, take a test light and check the hot wires, make sure you have 12 volt hot all the time on the one wire and then acc (hot with the switch on) wire to see if it is getting power. Check your grounds too!
