YotaTech Forums
-   Vehicle Audio & Home Entertainment (https://www.yotatech.com/forums/f96/)
-   -   Quick Amp Installation Question (https://www.yotatech.com/forums/f96/quick-amp-installation-question-60919/)
Billabong Jun 10, 2005 05:32 PM
Im about to hook up my amp and sub for my 99 4runner. I know i have the RCA's hook up into the headunit and go to the amp, but theres also a wire that i need to run from the stock wire harness to the amp... does anyone know which wire it is i need to splice into?? what color???
Corey Jun 10, 2005 05:40 PM
Not sure of the color, but I Googled 99 4runner remote amp turn on lead color and the first hit says you can use the electric antenna wire?
http://forum.ecoustics.com/bbs/messages/4/1235.html
I am also sure the answer is here somewhere on the forum too.
Here is some reading...
https://www.yotatech.com/search.php?searchid=851851
Billabong Jun 10, 2005 05:48 PM
thanks for your help. ive read through, but it seems as though, if i splice into the electric antenna wire, its only going to get power when the radio is on, not the cd player.
Billabong Jun 10, 2005 06:10 PM
could i just run it to a fuse that is activated only when the car is on? like the cigarette lighter fuse??
DavidA Jun 10, 2005 06:52 PM
Yes, it serves to notify the amp when the receiver is on so it will activate. You can put it on a switch or lighter, etc. Just remember it will run when power is applied to it and sometimes you don't want it on all the time.
Billabong Jun 11, 2005 05:32 PM
i got it all taken care of. i just tapped into the windshield wiper fuse and use the power from that.
thanks for all ur help.
89macrunner Jun 15, 2005 09:46 PM
your headunit should have a remote turn on lead thats what you want to use...that way your amp isnt pulling power for no reason if your radios off
NisAznMonk Jun 16, 2005 09:38 AM
wouldn't that mean that the amp would only turn on when it rains? :pop:
96LtdYota Jun 16, 2005 09:48 AM
no, your windshild wiper circuit has power only when the ignition is on... this works...
