YotaTech Forums
-   Vehicle Audio & Home Entertainment (https://www.yotatech.com/forums/f96/)
-   -   need to know speaker sizes (https://www.yotatech.com/forums/f96/need-know-speaker-sizes-245520/)
zulubravo34 Dec 2, 2011 06:39 PM
i got a 96 taco, extended cab 4x4. I'm looking at putting a brand new stereo, subs, the whole nine yards. But i am NOT spending an over the top amount. What size speakers will fit in the stock panels, tweaters, etc. and what size sub/ amp should i get? thanks
ThatGuy1295 Dec 2, 2011 08:18 PM
check out crutch field.com I got some polk audio door speaker for an 01 taco. Awsome!!
ThatGuy1295 Dec 2, 2011 08:21 PM
The sub is a tricky subject for the taco. Rear seat has limited air space. I used a sony explode 10'' with a 300watt RMS amp. Custom box under the rear seat. crappy sub but sounds good. I would recommend a better sub though.
i can post some pics if your curious.
zulubravo34 Dec 3, 2011 05:49 AM
if you could post a pic of how you have it set up that would be great. Im about to check out crutchfield now
ThatGuy1295 Dec 3, 2011 11:04 AM
2 Attachment(s)
Just bolted the sub to the back of the 1/8 steel plate. Did some misc caulking around the inside of the box to seal it up as best i could, kind of messy process but it helped. Also the box has an existing small chamber leading to the other side box that I just left alone. Kind of acting as a port.
ThatGuy1295 Dec 3, 2011 12:32 PM
http://i1201.photobucket.com/albums/...1295/photo.jpg
Sorry that last pic was way to small
ThatGuy1295 Dec 3, 2011 12:34 PM
This way you can still fold down the rear seat.
Look for subs that are designed for small air space and use a decent amp and this sound pretty good.
