YotaTech Forums
-   Vehicle Audio & Home Entertainment (https://www.yotatech.com/forums/f96/)
-   -   Anyone done an alarm install in a 1st gen 4Runner? (https://www.yotatech.com/forums/f96/anyone-done-alarm-install-1st-gen-4runner-60766/)
Ryan 25 Jun 8, 2005 02:14 PM
I just installed an alarm in mine and it does not work. I'm curious about the constant and ignition power sources and where to tap in. I tapped my constant into the line leading to the engine copmpartment fuse block and the ignition source (ign. column in front of the connector) should be right, it was verified with a multimeter. Any help would be greatly appreciated.
ldivinag Jun 8, 2005 06:56 PM
constant should be from the batt, fused of course.
IGN can be from the radio wiring harness.
Astralplane Jun 9, 2005 05:21 AM
Quote:
Tap connectors wouldn't work for me. Had to remove about 1/2 inch of the car wire sheath, pull wires apart (creating like an eye of a needle)in the middle then wrap the end of your alarm wire thru the loop and then around a few times. Lay the alarm wire along side car wire, electrical tape the connection and then zip tie the two together.
Does that make any sense?
I wire tapped the whole job and none took.
Wish I had a pic for you.
Ryan 25 Jun 9, 2005 11:17 AM
It doesn't really make sense. I'll fool around with it some more this weekend and run the wire direct from the battery.
Astralplane Jun 9, 2005 11:24 AM
Here's your alarm connection information:
1987-88 Toyota 4-Runner Security Information
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Black/Yellow Ignition Switch Harness
Accessory Blue/Red Ignition Switch Harness
Tach Black Coil or Black/White at Check Connector, marked IG
Brake Switch Green/White Brake Switch
Trunk Pin Green/Red (-) Driver's Kick Panel
Parking Lights Green Driver's Kick Panel or Fuse Panel
Head Lamp Red/White (-) Steering Column
Hood Pin n/a
Factory Disarm n/a
Door Trigger Black (-) Top of Fuse Panel 2 Pin Connector
Door Lock Brown/White (-) Door Control Relay behind left Front Speaker
Door Unlock Pink/White (-)
Horn Wire Green/Red (-) Steering Column, use Relay
Ryan 25 Jun 9, 2005 11:31 AM
Can I wire the constant off the harness or should that be run direct to the battery? Any idea where the parking lights run out of.
Thanks for all the info, its very helpful.
Astralplane Jun 9, 2005 11:55 AM
Yes, run it off the ignition switch harness.
Ryan 25 Jun 9, 2005 11:56 AM
Sweet, thanks man!
