YotaTech Forums
-   Vehicle Audio & Home Entertainment (https://www.yotatech.com/forums/f96/)
-   -   3rd gen stereo replacement (https://www.yotatech.com/forums/f96/3rd-gen-stereo-replacement-59846/)
spoonman May 24, 2005 09:45 PM
I have a 2001 T4R SR5 and I am going to be installing a new head unit. Im trying to find a guide, some pics or any info about how to pull out the dash to get the old unit out and put the new one in. Can anyone help?
DavidA May 24, 2005 09:52 PM
I got the instructions from Crutchfield. I can send them to you. But it is real easy. First pull up the emergency brake. Then OPEN the armrest. Pull up on the trim around the emergency brake. It will pop up. Then you can pull up the trim around the shifter. Then you pull out on the trim around the radio...it will be tougher but it will pop out. Unplug the electrical plugs from the trim.
The radio only has 4 screws securing the bracket from the front. That's it...very simple.
spoonman May 24, 2005 10:08 PM
Thanks man. If you could send the instructions, thatd be great. My e-mail is matt@ablegroups.com
SkyRat May 25, 2005 09:51 AM
Follow the instructions David Posted.
It really is easy.... It all pulls apart. No screws until you try and remove the actual unit.
Also, when you get to the point of removing the original unit. Remember to remove the original amp as well or the purchased wiring adapters will not fit.
DavidA May 25, 2005 10:39 AM
The amp is the little grey box behind and below. It really is that easy.
spoonman May 25, 2005 10:53 AM
cool...I was just making sure because I have my head unit coming in the mail and it will be here on friday. I want to have everything ready so I can install it then.
If you could still send me those instructions, I would appreciate it.
Amir904 May 25, 2005 10:56 AM
i replaced mine in my 98, i didnt have to take off the arm rest, is the 2001 setup different?
SkyRat May 25, 2005 11:01 AM
You don't have to take off the armrest. You open the armrest, that exposes the trim in front of it. When that trim is off, the trim around the shifter is easier to remove. When that trim is off, the trim around the unit and climate control is removeable.
BigJohn Jun 21, 2005 10:30 PM
hmmm i had no amp to remove in mine just a stock cd player and a fm/am/tape deck player i did see a box down below but it said something for the airbag
callmekurt Jun 22, 2005 12:48 PM
I swapped out my radio in my 99 Taco - went well. Now I have a 99 4runner, just got my Kenwood in this week (double DIN baby!). I'm hoping it goes as smoothly.
Good luck with your install.
K
BigJohn Jun 22, 2005 05:32 PM
do all 4runners have the amp cause i dont think mine had 1 like the stock amp
DavidA Jun 22, 2005 08:45 PM
I don't believe so, the basic radio setup probably did not have the amp below it. It is usually a silver metal box behind and below the stock stereo. I think only the deluxe or JBL systems have the amp.
Bob_98SR5 Jun 22, 2005 09:22 PM
sppon,
check out my writeup on the topic of headunit replacement: http://www.4runners.org/articles/headunit
Of note, my wife's 95 Camry head unit installation was identical w/ the exception of the front panel stuff.
Bob
callmekurt Jun 30, 2005 09:34 AM
I did mine last week -not too bad at all. I did have to remove the amp...any way to use that for something else?? hmm..
DavidA Jun 30, 2005 11:19 AM
Not worth the time to figure out the wiring in my opinion. :)
Gangus2006 Jul 1, 2005 06:08 AM
HU Removal How-To: (For 2000 4WD 4Runner)
1. Pull e-Brake Up
2. Put transmission in N
3. Remove Transfer Case Selector Knob
4. Grab rear-most portion of the transmission trim (where the TCS boot meets the trim). Pull up. Remove the rest of the way. There are 4 clips, 1 on each cornor of that piece.
5. Remove Ash-Tray and Cig Lighter.
6. Grab LowerMost portion of the dash. Pull. Work your way around. When you get to the top, be careful, as there is wiring. Unplug the 4 connectors. Leave the wiring at the bottom. Put the dash piece in the passenger footwell.
7. The HU is 4 screws, which can be removed with a screwdriver. Youre going to need the brackets on the side of your OEM HU to mount the A-Market HU.
Tips on reinstallation:
1. When you reconect the wire harnesses at the top, watch where they go. There are 4 harnesses, but 5 plugs. the Black harness fits into 2 spots, the clock plug, and a dummy. If you plug it into the dummy, your clock wont work. The dummy is the lower one of the two. You dont want to use that.
