2004 dash removal
Can someone tell me how to remove the dash in a 2004 4runner. I am installing a new stereo system and need to know how to remove the stereo and the door panels. Pics would be great. I went to the dealer but the guy told me he didn't have anything he could give me. This is my first post on this forum. It is great. Thanks.
my sig
Thanks for the help. Great site. I bet your system rocks. I plan on using CDT comps and coaxials, an Alpine HU and MTX amps. I hope my system turns out good. How did you hook up your speakers? Did you run new speaker wire directly to the speakers? I have the JBL system and I think the speaker wires from the radio run to the amp and then to the speakers.
new wire new wire dont run your new quality speakers on that crap from oem. also how much power you putting to them. the oem factory size wire might be to small.
Chris |
I'll have about 80 watts per channel to the comps and the rear coaxes and about 300 watts to a single 10" Audiomobile Evo. I plan on getting a 12" ED K series soon. Thanks for the help. I didn't see much on how top take the doors apart. I know you have to remove the arm rest and take out the screw there and take out the push pin at the top of the door. Then pry the door off. Did I miss anything?
Double Din Stereo
I'm wanting to put the Double Din stereo Kenwood MP4030 in my 04 4runner.I had this installed in my 00 Tundra.Can anyone tell me.??Will this install require any additional mounyting hardware.Some have said that their will still be a gap because the dash is a little wider..I called crutchfield and they said there shouldn't be any change.But wanted to see if anyone had replaced there or not.
Any help would be great. |
to remove the stereo you might also want to check this site. nice pics of the process.
http://www.castulucci.com/projects/carpc/oemnaviaccess/ |
