1st Gen 4Runner Rollbar Pod Speakers
6 Attachment(s)
After 23 years of abuse, 11 years by me, my OEM self amp speakers were about shot. The drivers side had been "blown" for the better part of a decade now and the passenger side was going. With kids now, my rear seats are ALWAYS up and my giant recovery(you know who you are :D)/fluids/gear box, hilift jack and gas can woofer taking up room I could hardly hear them anyways. Soooo, being INSPIRED by another YT'r on here(thank you Jerry! :wave:) I decided to add to my cheap stereo build further. Using some Sony xplode speakers I've had forever, some aluminum L-brackets and plumbing supplies I put these together on the cheap.
Attachment 198602 Attachment 198603 So I finished the pods after going to Home Depot for parts to fix a toilet. I found these vent diffusers that I thought would work great to "meter" or "port" the air out of the pods themselves. Attachment 198604 Attachment 198605 I cut down the lip and made it press fit it into the sewer pipe adapter for easy access to the wires and mounting bracket. Now I can infinitely adjust the tone. I could take off the three little medal support tabs...eh, makes it look "industrial"....:D The wires simply run down the roll bar into the side paneling and I put small spade connectors to directly plug into the factory wiring. Eventually, I'll put an actual mating connector in there and remove the OEM speakers. Attachment 198606 The rear view Attachment 198607 I think I invested $25 a pod for four pieces: Sewer pipe adapter, u-bolt for roll bar, diffuser, and a rubber cap/hose clamp(I no longer need the rubber cap but did retain the hose clamp). Maybe I'll paint them green...:D Thoughts? They sound great and actually put out A LOT of sound for only being pushed by the head unit at 52 watts. They don't take away from the rear view out of the back window and they only interfere when opening up my storage box but not enough to hinder getting stuff in or out. |
Sweet deal!! Now you might be able to hear them on the highway with the top down!! I know I can't hear my rear speakers at all. Good work.
:great: *edit - clean your garage!! hehehe :domo2: |
i dont get it... why are there metal tabs??? did you use super glue? why isnt it blue like your interior? does the adjustment really work? are these run on an amp? why is the sky blue?
Originally Posted by kiyobrown
(Post 51430497)
Originally Posted by vital22re
(Post 51430499)
nice. you might get better sound out of them if you made the cans bigger though.
Crutchfield sells a speaker baffle thats smaller then those cans. Just saying. :bigok:
And I believe that was the reason for the diffuser. |
Originally Posted by yotaman85
(Post 51430516)
fair enough, still a good job man. and paint them blue.
(Post 51430531)
it drowns out the dual noise makers in the back. :D
(Post 51430535)
paint them blue.
Good call, good call. :D |
Thanks! Basically I just wanted to see if this would work and perhaps inspire others. I'll probably paint them black to "blend" them into the roll bar.
cool mod....and they work well too eh?
good job man.....thanks for the mention too. |
Work good enough for me Jerry...besides it's YOUR fault I did this...:D
hehehehehehehe
:great:
um i believe my questions were not answered... so... get to it..
(Post 51430702)
(Post 51430499)
geeeeeeeeeeeeeezzuss......... too hold the speaker no probably gonna paint them black yes no the ocean :D |
thank you!!! :wave:
dork.
(Post 51431581)
dork.
Maybe that's why you two are friends. Just sayin' :bigok: |
guess that's why the three of us are eh? :D
