Time to paint the 1st gens pics 56k!!!!!
Well im going to be painting my two 1st gen 4runners the 84 is first then the 88. The 84 needs the most work there are a few rust holes that need to be patched up and some body work. Since I work in a bodyshop for almost 6 years this wont be to bad im looking forwared to it.
http://img69.echo.cx/img69/805/PDR_0058.jpg shot of the rear.damn skyjacker leaf is saging pas side http://img69.echo.cx/img69/6487/PDR_0057.jpg side shot removed all the stainless http://img69.echo.cx/img69/5522/PDR_0074.jpg passenger front side is down about 1/4 inch going to have to pull it up and fill the rest. sunroof leaked because of this.http://img69.echo.cx/img69/7657/PDR_0073.jpg hard to see from the pic but the inner fender is puling away from the firewall. going to have to weld it up and seam seal. http://img69.echo.cx/img69/4672/PDR_0072.jpg Same with this side. http://img69.echo.cx/img69/8103/PDR_0069.jpg corner was mashed in. fixed now sorry about the fuzzy pic. http://img69.echo.cx/img69/5254/PDR_0068.jpg the only rust spot in the tailgate jam little sandblasting and it will be fixed. http://img69.echo.cx/img69/7043/PDR_0067.jpg here you can see the rust spot in the door jam and on the out side of the wheel well. http://img69.echo.cx/img69/9522/PDR_0066.jpg more drivers side rust holes. http://img69.echo.cx/img69/2192/PDR_0065.jpg passenger side rust holes. http://img69.echo.cx/img69/9421/PDR_0064.jpg still thinking about spraying some color on the firewall and inerfenders and giving the motor a fresh coat. http://img69.echo.cx/img69/7474/PDR_0062.jpg another hard to see pic but there is a crack in the inerfender down to the wiring. |
http://img69.echo.cx/img69/5229/PDR_0061.jpgsame with this side but it starts from the bottem up.
http://img69.echo.cx/img69/3524/PDR_0059.jpg this side had a few dents still woking on it. http://img69.echo.cx/img69/7232/PDR_0060.jpg another shot http://img69.echo.cx/img69/5670/PDR_0071.jpg the top is getting all the texture sanded off and is going to be gloss black going to pop the windows out I dont like masking stuff off that is easy to get out of take off makes for a nicer job http://img69.echo.cx/img69/3008/PDR_0070.jpg |
did some more work today pulled all the glass out of the top
http://img249.echo.cx/img249/9116/PDR_0088.jpg pulling the rear windows is pretty easy get the nuts off from the inside and push the glass out stick a screwdriver in between the glass and the top and cut the sealer around the window. http://img249.echo.cx/img249/8109/PDR_0089.jpg no need to cut the bottem just pull it down. http://img249.echo.cx/img249/680/PDR_0091.jpg the fronts are a little harder start by pulling the rubber out from the inside then pull the rubber out in the pic. http://img249.echo.cx/img249/6156/PDR_0092.jpg very easy pry the window out do not pry on the gutter part of the top its easy to break. http://img249.echo.cx/img249/1701/PDR_0094.jpg http://img249.echo.cx/img249/6720/PDR_0093.jpg then started sanding with 220 on the DA sander. after the 220 it going to be sanded with 320 and then primed. http://img249.echo.cx/img249/6268/PDR_0100.jpg but first i have to fix these cracks from leaning it up on the side of the shop. http://img249.echo.cx/img249/6117/PDR_0099.jpg http://img249.echo.cx/img249/8832/PDR_0096.jpg |
shot of my body work still need to fix thoes rust holes.
http://img249.echo.cx/img249/902/PDR_0085.jpg nice and straight on this side. http://img249.echo.cx/img249/9510/PDR_0082.jpg not so straight on this side. the black line is where the body line should end. If you look close you can see the body line is about 1" under the black line. http://img249.echo.cx/img249/650/PDR_0078.jpg http://img249.echo.cx/img249/8099/PDR_0077.jpg better shot of the cracks. |
all these veiws and no posts :( . Should have some more pics tomorrow.
That looks great. I repaired all the rust in ine and repainted it last year. I had a bit more to repair than you in the rust department. My a-pillar was about gone on the passenger side. :eeek:
So, what color are you going with? I see you said black for the top, but was just wondering if it was going to be the same all the way around. BTW. I like the Ford V8 in there. :great: |
Also, do you think the cracks in the front are from the torque of the motor? I've never seen on crack in those places before..
here is the color its a 95 toyota color. We added some pearl. wish my camera would focus :(
http://img101.echo.cx/img101/6398/pdr01065vn.jpg |
Dude that color is gonna look great!
Are you going to replace the plastic rocker guards for the rear fenders. I welded up the holes and used gravitex (anti-chip) in the rocker area and then painted over it. It also gave it a nice texture in the area! Here is a pic of it before I painted over it. http://memimage.cardomain.net/member...78_11_full.jpg [another thing it could be is the tires they shake the whole truck up untill 50mph. I should just find a new nose ] have you tried using antifreeze or equal in the tires to balance them? Ive heard of this, but dont know if it works.... Keep the pics coming I love watching the progress! :bigok: |
you know i was thinking about leaving them off but changed my mind they are in great shape so they go back on. I will check into the antifreeze trick thanks for the tip
few more pics
http://img30.echo.cx/img30/9007/pdr01100ud.jpg http://img30.echo.cx/img30/881/pdr01094sl.jpg http://img299.echo.cx/img299/2470/pdr01124tt.jpg http://img232.echo.cx/img232/8930/cimg01102xj.jpg took care of the lip filled it in with some angle and some mud |
man that is gonna look good keep it updated .What kind of shackles are those on there how much lift do they give :rockon: and where did you get them from?
some more pics
http://img134.echo.cx/img134/3416/CIMG0251.jpg http://img134.echo.cx/img134/9233/CIMG0250.jpg http://img134.echo.cx/img134/399/CIMG0300.jpg http://img134.echo.cx/img134/7541/CIMG0299.jpg these two dents would be from my g/f slaming the seatbelt in the door :soap: http://img134.echo.cx/img134/8030/CIMG0310.jpg http://img134.echo.cx/img134/4731/CIMG0307.jpg http://img134.echo.cx/img134/3486/CIMG0306.jpg this is why i dont use bondo that much,stupid air bubbles make holes in it that have to be filled. |
time for primer
http://img134.echo.cx/img134/2199/CIMG0304.jpg http://img134.echo.cx/img134/3833/CIMG0303.jpg http://img134.echo.cx/img134/9556/CIMG0290.jpg http://img134.echo.cx/img134/9434/CIMG0289.jpg a little block sanding before another coat of primer http://img134.echo.cx/img134/8361/CIMG0287.jpg http://img134.echo.cx/img134/3568/CIMG0302.jpg http://img134.echo.cx/img134/1540/CIMG0301.jpg http://img134.echo.cx/img134/3042/CIMG0297.jpg last coat of primer on the body http://img134.echo.cx/img134/8925/CIMG0318.jpg http://img134.echo.cx/img134/1752/CIMG0317.jpg http://img134.echo.cx/img134/8242/CIMG0316.jpg http://img134.echo.cx/img134/746/CIMG0315.jpg |
I've rarely seen anyone post up do good bodywork surfacing- Nice work, it's going to look great when you finish
http://img134.echo.cx/img134/442/CIMG0314.jpg
http://img134.echo.cx/img134/2424/CIMG0313.jpg http://img134.echo.cx/img134/8315/CIMG0312.jpg http://img134.echo.cx/img134/4929/CIMG0311.jpg well hopfully I will get this thing blocked out and ready for paint today. might even shoot the body so it can be rolled out side and then i can work on the fenders,doors and hood :great: |
dude,
man, if i had your skills...wishful thinking :) can't wait to see what it will look like. nice color choice too! bob |
