Solution for e-brake cable on lifted first gen?
My e-brake cable seems too short for the travel my 1989 4runner has on the rear suspension. I'm running 4 inch marlin rear springs and the e-brake cable looks pretty unhappy at rest, let alone at full droop.
Can I lengthen the cable? Shoot, I have to lengthen the e-brake arms anyway. Maybe I can get fancy and build an L shaped extension to handle the height issue (thick pack+ rotated housing) and the length issue. Tell me about what you did! I am choosing to retain some kinda e-brake solution so "just cut it off" isn't a good answer for me. (but thanks anyway.) |
most people go with the trans brake. I has better holding power on inclines and gets rd of the lines on the axle. Marlin, Sky, All-Pro and a few other make one.
Loosen/relocate the e-brake cable clamps as they run along the back of the frame.
Then you can put a spacer on top of the axle: http://www.4crawler.com/4x4/CheapTri...III/Raxle3.jpg and extend the e-brake levers to match: http://www.4crawler.com/4x4/CheapTri...-Brake-Mod.jpg http://www.4crawler.com/4x4/ForSale/...rakeExtensions I run the stock cable on mine, and even have the front crossmember where the cable attaches lifted 3" (rasing the gas tank the same) and it works fine. |
I have a line-lock on my 83.
Roger has it spot on. Very easy to do and should accommodate 5" of lift easy.
Thanks folks. The e-brake cable along the frame...Is that a drop fuel tank thing?
I cut the old pivot mount off the axle and welded on a taller one out of .25 bar stock. Still need to lengthen the levers a little bit to get them off the springs (they barely touch) |
