Rollbar spare tire mount
Ordered 2" greenhouse clamp (buttjoint style) from greenhouse supplier. Clamped to rollbar then to pipe stub with plate welded to it. Three wheel studs on plate. Could fit a 33" under rollbar. If I adjusted the stub pipe, maybe a 35". I don't crawl but use plenty of rough roads - holds spare well. Pictures if interested.
Lets see the pics
Workin' on it.
3 Attachment(s)
Clamp is removable from rollbar, adjustable up and down rollbar. Just need to weld a stub pipe to wheel plate, and drill holes for studs. Enough room between tire and rollbar to lay a hi-lift against the clamp and fasten in some way. The allen set screw leaves a dimple, if you are a purist.
I mean, the clamp action leaves an impression in rollbar.
Good idea with the greenhouse clamp.
I've had a bug in my brain for doing something like this the last couple days. I like this set up... looks a lot simpler than some of the other examples I've found. Thanks for posting.
thanks for a great idea.
great idea, very clean looking.
Got a link to that green house clamp? Really like this idea!
link to quik-clamp
