You need to take a drive up here some weekend.
So I can give you a very intensive hands on welding seminar The design is good your fitting looks good from the pictures . your welding needs some work. It might be from using the welder you are and not enough arc time. Overall not bad |
Originally Posted by wyoming9
(Post 52116425)
So I can give you a very intensive hands on welding seminar The design is good your fitting looks good from the pictures . your welding needs some work. It might be from using the welder you are and not enough arc time. Overall not bad I am going into my second year of welding instruction through my Local Union.. It it is mostly Stick welding.. which I am actually pretty good with(1 year of school already of all stick welding all postions..) For my 2nd attempt ever building anything I think it turned out pretty good. at least I did it myself lol. |
how much did that cost you in materials? looks super good. and was it tough to figure out the proper angles for the corner tubing?
Originally Posted by AmirK
(Post 52117126)
I have approx 350 into the front and rear bumpers total in material, welding wire, tube, plate, paint, etc. It is a little pricey to get the material but when you think about it, you save a bunch of money compared to buying it from somewhere. The angles weren't too hard, and i could duplicate them if i needed too. I bent the bottom tube as one piece, but because i was just winging it I needed to adjust the angle a little bit. I cut it and seam welded it. |
well done. what kind of steel did you use? i dont have access to a pipe bender so i'll probably end up doing a lot of cutting and welding corners, but it'll be good practice.
What size of tubing did you use?
That looks awesome, What would you say you paid in metal to do the entire bumper?
Originally Posted by andersej
(Post 52122030)
Originally Posted by xdunaticx
(Post 52126698)
As stated earlier in the Thread, I have about 350$ in materials TOTAL, including shackles welding wire etc etc for the front and rear bumpers. (if you want to see the front look through the thread until you find the link) If you are interested in something here on YT or other forums, a lot can be accomplished and learned simply by reading. |
looks great man thanks for your input!
