YotaTech Forums
-   The Fab Shop (https://www.yotatech.com/forums/f88/)
-   -   Raidator in the bed (https://www.yotatech.com/forums/f88/raidator-bed-179523/)
Bongo Apr 13, 2009 11:39 AM
Raidator in the bed
I want to put the raidator in the bed of my truck. What is the best way I was told that u can use exost pipes for the hosing. Any help would be awesome.
dropzone Apr 13, 2009 11:46 AM
i would run stainless or copper. Exhaust tubing will rust IMO. Hope the Stock H20 pump is up to pushing it that far....
Bongo Apr 13, 2009 01:35 PM
I remember somone sayin something about the pump not bein able any recomidations on on that might?
wyoming9 Apr 16, 2009 11:07 PM
I don`t know about the water pump.
I was wondering what sort of electric fan or fans you will be using??
i don`t know why exhaust pipe wouldn`t work as long as you paint it the antifreeze will protect the inside .
Stick_Figure Apr 17, 2009 07:20 AM
you can buy electric pumps at summit, jegs, or probably any local stock car parts supply place. However, the stock pump may work, i know the MR2's never used any special water pump to plumb the radiator to the front of the car. That's roughly a 3 gallon coolant system w/ the pipe capacity, plus the radiator and engine.
I would be more worried about the fans, shroud and having enough alternator to keep the fans going all the time.
