rag joint delete help.
I need to get rid of the rag joint on my 91 truck, I would like to go to a universal joint style for clearance. I have searched but cant find the exact info im looking for.
I am not sure how many splines and what size my steering gear is, is there a universal fit joint that works? anyone have a part number? will the pre 82 or so shafts work? any input is helpful, thanks |
Just what are you working with you need to change things ??
Are you going to a solid front axle?? Engine swap?? I think the easy way would be measure and count the splines.:welder: |
if it was me i would source another shaft from the salvage yard and cut off the u joint with a couple inches of shaft. cut off rag joint and weld ujoint in place of the rag joint. might be a little ugly buy cheap and easy and if you can weld good strong too
I can't be the first guy to do this. Someone surely makes a kit...I hope?
you are gonna have to weld
http://www.flamingriver.com/index.php/products/c0005 |
Well if I have to weld , fine, but I guess I don't need anything then. I'll just weld in metal bar to replace rag joint. It is a straight shot anyway
| All times are GMT -8. The time now is 04:58 AM. |
