Project: Save The Yota!
heres my trucks current specs and my project at hand: (click thumbnails to enlarge)
95 4runner Sas 85 runner front axle 5.29 gears Longfields ARB Air Lockers 4" marlin Crawler front leafs 1" rear superlift with 3" poly Spacers 3" body lift 8000lb winch my rear axle is cracking where the link mounts are welded on my front shock mount is cracking where its welded along the frame my cheap ass superlift springs are sagging my superlift link bracket extensions are hanging down so far that obstacles taller than 16" will hit the brackets instead of my rear tire So here is what im doing to fix all that crap: taking off the 3" body lift (this truck is waaay too high and tippy) Im cutting off the rear of the body and turning it into a quad cab flatbed relocating the fuel cell to the spare tire mount area cutting off the stock 4link and using trail gears rear axle link mounts fabbing up a custom crossmember for my links to mount on fabbing up custom longarms with johnny joints putting in aisin hubs and rebuilding my front knuckles / replacing the wheel bearings fixing the cracked frame and turning my shock tower into shock hoops putting yukon gears in my rear axle taking off superlift crap and putting 6" custom progressive coils bend and weld myself a nice rollcage Heres some pics: Heres a pic of my truck (before pic) http://i154.photobucket.com/albums/s...mini228j/3.jpg http://i154.photobucket.com/albums/s...mini228j/2.jpg Trashed Pinion http://i154.photobucket.com/albums/s...j/IMG_1853.jpg Cracked axle housing http://i154.photobucket.com/albums/s...90418_0008.jpg http://i154.photobucket.com/albums/s...90418_0009.jpg Superlift 4link lift (note the long bracket extension hanging down like 16") http://i154.photobucket.com/albums/s...90418_0022.jpg http://i154.photobucket.com/albums/s...90418_0023.jpg Cracked frame (front shock mount weld failure) http://i154.photobucket.com/albums/s...90418_0020.jpg http://i154.photobucket.com/albums/s...90418_0021.jpg http://i154.photobucket.com/albums/s...90418_0019.jpg In these pics, Ive taken the axle off, I have my dropout complete and gears are all set (Thanks Wayne!), Ive ripped out the interior, and chopped the rear side of it off. Tomarrow I will drain the gas tank and take it off to be relocated after Im done with the cab fabrication and rear suspension. I was planning on fabbing up the new crossmember this weekend but it will have to wait until Thursday, the shipment on my new plasma cutter was delayed. I think Ill start working on the front side until it gets here, Ill try to have the knuckles rebuilt, the aisin hubs put in, shock tower mounts ground off, and the cracks in the frame fixed. http://i154.photobucket.com/albums/s...ni228j/001.jpg http://i154.photobucket.com/albums/s...ni228j/003.jpg ........... BTW I think all my neighbors hate me now.... 8) got my gas tank removed and cut out the spare tire crossmember, ill need to cap that off with a new cross member on the end to reinforce it. http://i154.photobucket.com/albums/s...ni228j/017.jpg http://i154.photobucket.com/albums/s...ni228j/016.jpg mocked the new mount in place, welded it in- only tacked the lower link mounts incase they need adjusted http://i154.photobucket.com/albums/s...ni228j/028.jpg http://i154.photobucket.com/albums/s...ni228j/026.jpg http://i154.photobucket.com/albums/s...j/IMG_2269.jpg http://i154.photobucket.com/albums/s...j/IMG_2272.jpg I decided to start doing my knuckle rebuild http://i154.photobucket.com/albums/s...ni228j/020.jpg I put blocks up so that we could put in the crossmember http://i154.photobucket.com/albums/s...j/IMG_0008.jpg had to massage it with my hammer a little so it would fit under the body http://i154.photobucket.com/albums/s...j/IMG_0005.jpg a smidge too long on one corner, had to grind it down http://i154.photobucket.com/albums/s...j/IMG_0007.jpg tadaaa! crossmember is welded in place on the collars, just need to drill holes and bolt it in http://i154.photobucket.com/albums/s...j/IMG_0009.jpg Got the rear axle together with wheels on, slid it under the truck so we can mock it up soon http://i154.photobucket.com/albums/s...j/IMG_0010.jpg Heres a pic of my repaired cracks and shock hoops http://i154.photobucket.com/albums/s...j/IMG_2201.jpg http://i154.photobucket.com/albums/s...j/IMG_2202.jpg http://i154.photobucket.com/albums/s...j/IMG_2205.jpg I was getting ready to cut the parts for the cab and i figured out that I could make the luggage rack on top work, just make it shorter http://i154.photobucket.com/albums/s...j/IMG_0016.jpg Here it is cut off, getting ready to mock it in place http://i154.photobucket.com/albums/s...j/IMG_0020.jpg I cut the top of the bed off and I will use it to seal the window http://i154.photobucket.com/albums/s...j/IMG_0021.jpg Here is the track the window used for going up and down... Im going to cut it into 1/2 and use it for the bottom window supports http://i154.photobucket.com/albums/s...j/IMG_0022.jpg Finally got it mocked in place, almost ready to weld http://i154.photobucket.com/albums/s...j/IMG_0026.jpg http://i154.photobucket.com/albums/s...j/IMG_0027.jpg Here in the next week Im going to be blasting out as much as I can, the association of homeowners has been informed of my vehicles state and has informed me of my infraction lol! 8P OK here it is, I have the back wall welded in place pretty well.. welds are ugly as hell, I guess there is some kind of learning curve to welding on sheet metal- I definately would rather not in the future! I also have the roof portion welded up. Tomarrow Ill be going to buy some metal tubing for supports and filling in the rest / reinforcing everything. Here I have the back welded in finally... I tried out the back of the taco cab but it didnt work out so well, I was like a half inch short, so heres my new cab end. http://i154.photobucket.com/albums/s...j/IMG_0033.jpg http://i154.photobucket.com/albums/s...j/IMG_0034.jpg Next i cleaned up the top portion and drilled some holes in it, measured to make sure it was centered and symetrical, then welded it up.. please heh dont laugh at these welds- this is harder than it seems before you do it! http://i154.photobucket.com/albums/s...j/IMG_0037.jpg http://i154.photobucket.com/albums/s...j/IMG_0039.jpg Heres that track, I decided to cut one of them into 3 http://i154.photobucket.com/albums/s...IMG_0041-1.jpg I paid attention in art class! http://i154.photobucket.com/albums/s...j/IMG_0042.jpg http://i154.photobucket.com/albums/s...j/IMG_0043.jpg http://i154.photobucket.com/albums/s...j/IMG_0044.jpg http://i154.photobucket.com/albums/s...j/IMG_0045.jpg http://i154.photobucket.com/albums/s...j/IMG_0046.jpg Welded them into place- I tried tacking the top in first then working my way down, bending it along the contour of the roof as it curved into the wall but it didnt work too well, I had to cut it and reposition it. http://i154.photobucket.com/albums/s...j/IMG_0048.jpg This side I started on the bottom and rolled it over on top with a hammer- had to grind a little here and there but it worked out alot better than the other side. http://i154.photobucket.com/albums/s...j/IMG_0051.jpg Welded up the support structure for the rear area and window http://i154.photobucket.com/albums/s...IMG_0052-1.jpg Blocked it up with wood. You can see I welded those window track onto a piece of 1.5" angle and welded it to the support square tube. http://i154.photobucket.com/albums/s...j/IMG_0053.jpg Welded everything together http://i154.photobucket.com/albums/s...j/IMG_0054.jpg http://i154.photobucket.com/albums/s...j/IMG_0055.jpg http://i154.photobucket.com/albums/s...j/IMG_0058.jpg I am working on welding the bottom in, designing how to make it look finished- I have an idea that may look amazing- and welding that weather strip on the bottom. Anyone know what this thingy does? Its some kind of hook that went on my track bar and is mounted to my brakes... http://i154.photobucket.com/albums/s...IMG_0061-1.jpg Cut these old bump stop mounts off http://i154.photobucket.com/albums/s...j/IMG_0059.jpg http://i154.photobucket.com/albums/s...j/IMG_0060.jpg Here you can see my paint on the cab back and the cut out bump stop panels http://i154.photobucket.com/albums/s...j/IMG_0064.jpg Painted my axle http://i154.photobucket.com/albums/s...j/IMG_0089.jpg Building new upper arm mounts http://i154.photobucket.com/albums/s...j/IMG_0090.jpg Built my links http://i154.photobucket.com/albums/s...j/IMG_0093.jpg Built my suspension mount- thinking im going to either make another arm that goes back for more support, or gusset it.. http://i154.photobucket.com/albums/s...j/IMG_0084.jpg http://i154.photobucket.com/albums/s...j/IMG_0086.jpg http://i154.photobucket.com/albums/s...j/IMG_0088.jpg Put my hybrids together - BOOYA! Trying to imagine how they will move with bump and droop http://i154.photobucket.com/albums/s...j/IMG_0092.jpg Heres some pics of the truck without all those tarps and welding screens around it http://i154.photobucket.com/albums/s...j/IMG_0081.jpg http://i154.photobucket.com/albums/s...j/IMG_0083.jpg http://i154.photobucket.com/albums/s...j/IMG_0094.jpg http://i154.photobucket.com/albums/s...j/IMG_0079.jpg ok all updated... Im stuck right now waiting for bolts to come in the mail and Im still trying to find an 18mm drill bit... /rant on To all who decide to do this DO NOT BUY 18MM CREEPER JOINTS!!!!! I called over 50 stores, apparently nobody in the US makes or sells 18mm, they go from 16 straight to 20, machine shops charge 100 bucks per to make them since they have to harden each one and machine each one 2x, fasteners can get them but the shoulder is about an inch too short, and finding an 18mm drill bit is just as rediculous.... Why trail gear would sell me an 18mm creeper joint without mentioning these issues is beyond me... maybe they hate repeat customers? /rant off... Once I get these things the links will go right in, my coilovers are all set and ready to go in, and I will get started on the gas tank. Im debating on letting someone else do the bodywork so it actually looks decent, Im going trade of all the chrome for black, and I think Im going to take it down to the local maaco and get a $300 dark grey paint job before I build my exo. Here I am trying to fab some new link mounts with multiple adjusting points, wewt I got to use my drill press! http://i154.photobucket.com/albums/s...j/IMG_0096.jpg Using the old mounts I had fabbed for comparison I checked to see if my 45/64 drill bit would work well or if I would have to step it up to a 23/32 bit http://i154.photobucket.com/albums/s...j/IMG_0098.jpg Heres the new mount, it works!!! It was a better fit than the original one. http://i154.photobucket.com/albums/s...j/IMG_0099.jpg Got these all drilled ready to go in http://i154.photobucket.com/albums/s...j/IMG_0100.jpg OMNOMNOMNOMNOM! LUNCH BREAK! http://i154.photobucket.com/albums/s...j/IMG_0047.jpg After lunch I hired some help- She works for cookies! and apparently shes an expert in the field of tires? http://i154.photobucket.com/albums/s...j/IMG_0102.jpg http://i154.photobucket.com/albums/s...j/IMG_0103.jpg http://i154.photobucket.com/albums/s...j/IMG_0104.jpg Got one link in... had to pull the axle to drill out the holes (they were 9/16 holes) http://i154.photobucket.com/albums/s...j/IMG_0101.jpg Links in! Just need to weld up the upper frame mounts tomarrow, I decided to wait until I could see to do it. http://i154.photobucket.com/albums/s...j/IMG_0108.jpg http://i154.photobucket.com/albums/s...j/IMG_0110.jpg So tomarrow Ill see about making brackets for the coilovers and putting in the gas tank. I went to tighten all my links and I didnt have the right size wrenches- It was Sunday and nobody that was open sold it, so I decided to open my own line of tools! http://i154.photobucket.com/albums/s...j/IMG_0179.jpg Got my brackets made and jacked it up to put the hybrids on http://i154.photobucket.com/albums/s...j/IMG_0143.jpg I had to put blocks on the jack and my high stands didnt go high enough to touch it- and i still had to fight the coilovers by fircing the springs in place because theyre so damn long http://i154.photobucket.com/albums/s...j/IMG_0145.jpg Got em all set, just need to take em down to altons tire to get some nitrogen http://i154.photobucket.com/albums/s...j/IMG_0146.jpg side view... stance is a little high in the back but it will settle when i build the flatbed tomarrow. http://i154.photobucket.com/albums/s...j/IMG_0147.jpg Had to trim one side of the gas tank lip to get it to fit but its in! http://i154.photobucket.com/albums/s...j/IMG_0149.jpg got the gas tank all hooked up, poured gas into it, and she fired right up! http://i154.photobucket.com/albums/s...j/IMG_0180.jpg cleaned up the wires and lines so they dont get smashed http://i154.photobucket.com/albums/s...j/IMG_0181.jpg My gas tank's drain plug was leaking like a trailer park mobile home, I struggled with it all day- I ended up getting some heat resistant thread sealant- sets in 4 hours, completly set in 3 days. I am going to leave the gas tank empty until its fully dry while I complete all my welding on the flatbed and bottom of the rear window. I went through the rest of the truck finishing up maintenance stuff, bled the brakes, gave it a good lube order, double checked every bolt I put into the rear end for tightness, put some sealant on my welds, and hooked up my one remaining brake light- it worked! In 3 days I should have my flatbed finished and it will go away to the body shop where it will get some new front fenders, some body work omn the rear chopped up portion, all chrome will be replaced with black body parts (grill trim ect.) and some new paint- dark grey. When I get it back Ill build my front bumper, fill in that gap from the body lift, and start planning my roll cage. Im considering going down to the local car audio store and letting them put a big sticker on my back window in exchange for tunes and installing my cb somewhere on the dash instead of my floorboard. Ill keep you guys updated- after I put 500 miles on the new gears in the rear end Ill post some test run pics for sure. ok sorry for the long wait on updates but college has been keepin me busy. After fixing the leak on my gas tank I moved the lower coilover mounts further out and crossed my fingers that it wouyld still clear on full stuff... http://i154.photobucket.com/albums/s...j/IMG_0307.jpg It worked! I have like a quarter inch clearance still, just barely made it! http://i154.photobucket.com/albums/s...j/IMG_0308.jpg Then i framed out the bottom portion of the rear window and put a gasket on tjhe lower portion to make it look finished. http://i154.photobucket.com/albums/s...j/IMG_0311.jpg next I framed out the flatbed http://i154.photobucket.com/albums/s...j/IMG_0314.jpg http://i154.photobucket.com/albums/s...j/IMG_0313.jpg Then I put in some cross members to support the bed and put on the rear of the flatbed http://i154.photobucket.com/albums/s...j/IMG_0316.jpg http://i154.photobucket.com/albums/s...j/IMG_0315.jpg Next I cut a hole in the floor to make room for the crossmember i built on my links so that I could take off the 3" body lift- I accidentally cut through my arb air lines and had to get a union from granger to repair it http://i154.photobucket.com/albums/s...j/IMG_0301.jpg http://i154.photobucket.com/albums/s...j/IMG_0302.jpg I fabbed up a cover for the hole which I will later fiberglass in (when I tare out the carpet in preperation for lining the tub with bed liner) http://i154.photobucket.com/albums/s...j/IMG_0303.jpg http://i154.photobucket.com/albums/s...j/IMG_0304.jpg http://i154.photobucket.com/albums/s...j/IMG_0305.jpg At this point I decided it was time for a test run! This is where we visited http://i154.photobucket.com/albums/s...j/IMG_0400.jpg http://i154.photobucket.com/albums/s...j/IMG_0403.jpg Here is my truck in action! http://i154.photobucket.com/albums/s...j/IMG_0379.jpg http://i154.photobucket.com/albums/s...j/IMG_0380.jpg http://i154.photobucket.com/albums/s...j/IMG_0382.jpg http://i154.photobucket.com/albums/s...j/IMG_0390.jpg http://i154.photobucket.com/albums/s...j/IMG_0360.jpg http://i154.photobucket.com/albums/s...j/IMG_0361.jpg !@#$%^&*()!@#$%^&*()!@#$%^&*()!@#$%^&*()_!@#$%^&*( )!@#$%^&*()!@#$%^&*()_!@#$%^&*() Here is a video (keep in mind when I did this my rear lockers were inop and my fronts were working intermittantly, and I was using my lame pro comp street tires instead of my pitbull rockers because I havent put on my new fenders yet http://www.youtube.com/watch?v=vafRihDFJIk !@#$%^&*()!@#$%^&*()@#$%^&*()!@#$%^&*()_!@#$%^&@#$ %^&*()@#$%^&*()@#$%^&*()@#$% I have finished most of the flatbed here, I wanted to show how I tied it in to make a wheel well http://i154.photobucket.com/albums/s...j/IMG_0457.jpg http://i154.photobucket.com/albums/s...j/IMG_0460.jpg Started the body work http://i154.photobucket.com/albums/s...j/IMG_0459.jpg http://i154.photobucket.com/albums/s...j/IMG_0458.jpg yesterday I broke my axle driving on pavement... wth? http://i154.photobucket.com/albums/s...j/IMG_0456.jpg http://i154.photobucket.com/albums/s...j/IMG_0455.jpg Almost finished! Ill keep you guys up to date here and there, be patient and stick it out! I finally did it, all finsihed guys. Heres the final pics, hope you guys like it as much as I do! http://i154.photobucket.com/albums/s...j/IMG_0948.jpg http://i154.photobucket.com/albums/s...j/IMG_0950.jpg http://i154.photobucket.com/albums/s...j/IMG_0947.jpg |
My goodness talk about starting 20 projects at once! Glad to see you are saving it though. It's unfortunate about the association where you live. I live in an apartment complex and my garage faces no less then 50 apartments so I know they hate me. And Welcome to YotaTech!
saw your thread on pirate... those little thumbnails blow! especially on a build like this:D
edit: just notice the rodda paint can jackstands...you must have a lot of faith or good life insurance |
lol those are only holding up my crossmember while I get ready to weld it in place, I made the damn thing out of 3/8"x3"x5" rectangular tube, it probably weighed 60lbs!
Wow thats a project. Subscribed, and excited to see the finished product.
this makes me glad i live in a cresent with half old people and half young dudes wrench on stuff after work.. o and i live in canada with none of this home owners unions bull ish
updated, see original post
updated see original post- lots of work finished today!
Haha just saw this on Pirate yesterday. I'm subscribing.
:popcorn:
Sub'd!!!
heres my calculation for the 4link... not sure what it means though
http://i154.photobucket.com/albums/s...228j/4link.jpg |
Originally Posted by toylocost
(Post 51161100)
subscribed. nothin like a little chop chopage
anyone know enough about links to tell me if those numbers are good to go?
Looking good! What welder you usin??
great work!
Subscribed... cant wait to see more :banger: |
looking great so far.
If TC gets in here, he will def be able to help you out with the numbers, he designed his own custom 4 link in his 4Runner. Keep it up! |
that is a lincoln 180 hd, got a sweet deal on ebay almost half off
Ive been measuring this all morning, im so scared of messin this up I dont think Ive ever measured anything this much in my life! Here are some more accurate numbers, and Im pretty sure im going to roll with it- looks like a solid design, and I found a version of this calc that has a geometry program for bump and droop, doesnt look like it will bind, pinion angles look good ect.
http://i154.photobucket.com/albums/s...evisedcalc.jpg |
| All times are GMT -8. The time now is 01:39 AM. |
