Divorced T-case
Is there a fab company that can make a T-case plate and flange the input shaft? My swap is coming to fruition and if I can just divorce the t-case, all my problems will be solved expect building motor mounts! 😁
what are you doing that warrants a divorced case?
i know it's been done, usually by Suzuki wheelers since Toyota parts are a common upgrade and the stock Samurai layout is divorced. you can easily google divorced toyota transfercase and get lots of results |
:coffee:Any thing can be built if you want to spend the$$$$
A drawing of just what you want is a big help The F250`s of the seventies had the transmission and transfer case separate with a drive shaft between them. What you want should be pretty easy to design and build. I also need to ask Just Why ???? |
I've seen this done on an older K5 blazer, for equal length drive shafts and to reduce the angle on the front shaft. different truck and case I know but same concept.
Then the never came back I am curious if it was ever done.
| All times are GMT -8. The time now is 04:29 AM. |
