Best way to fix this the right way. Advice please
Old 02-03-2018, 07:16 AM
Co_94_PU's Avatar
Hot rolled steel will need more prep work to paint/seal or weld, it is covered in a slag/film from the process.
Galvanised doesn't hold paint very well, and is toxic to weld.
Old 02-03-2018, 11:20 AM
95yoda's Avatar
Yeah hot rolled but what about cold rolled. I read that's the stuff to use.
Old 02-03-2018, 04:08 PM
Thommo Thompson's Avatar
Yeh stay away from zinc metal coated steel. You really Cannot paint it succesfully. Paint is where your rust inhibition should be, funnily, in the form of zinc phosphate primer hehe. Like mentioned, ud really want to clean the steel, no matter which steel u go at a minimum with degreaser, then roughen with a cupbrush on a grinder, then wax n grease remover, then zinc rich primer, then put it all together, then zinc phosphate primer, then topcoat then underchassis black.
Old 02-04-2018, 04:30 AM
95yoda's Avatar
Sounds like a good plan! Now I will look for new bolts and bushings for the cab mount
Old 02-06-2018, 12:26 PM
  #25
95yoda's Avatar
Fixed
Extremesolo
03-31-2024 01:25 AM
kscanuck785
04-05-2011 06:22 AM
Texas_Ace
05-30-2007 02:51 PM
Quick Reply: Best way to fix this the right way. Advice please
