1985 Waggoneer Front Axle??
I've got one here locally I can get for probably $50 with little to now rust and in good working condition. Will this work on my 1997 4runner?
Chris |
Chris |
I like my IFS, because it never ceases to amaze me. But, I beleive there's only three things holding me up from running all the trails at Tellico:
1) Front Locker 2) More height 3) More front flex I've decided that locking the front end of my IFS will never happen, because it's too weak. So, my only option is to SAS it for the added strength, but also for the added flex. In addition, after moving my gas tank, lengthening the rear links, doing my drivetrain lift, and raising it up about 6", it will be unstoppable. That's my plan, but if I do buy an axle, I want to make sure it's one of the better options for it. Chris |
There are better experts on axles than me, but this sort of discussion makes me laugh.
When does front flex hold you back? I do wheel stands and it works fine. IFS does 99% of what 95% of people think it cannot. |
umm if you want ive got a toyota straight axle pm me
When does front flex hold you back? I do wheel stands and it works fine. IFS does 99% of what 95% of people think it cannot. Chris P.S. I agree that most of the people on this board never even get close the limits of their IFS, but if anyone has ever wheeled with me, they know I have on numerous occasions. |
Chris |
Really? What's the details on it?
Chris Chris |
Old Toys have the wrong side diff, Steve enlightened you.
The best carrier replacement is an ARB. I have wheeled quite a bit with Steve on some hard trails. He has broken exactly one CV. It was not a catastrophic break and I still think it was a fluke. Run 35's with a nice low truck. When you break CV's every trip, start saving for CTM's. |
I have wheeled quite a bit with Steve on some hard trails. He has broken exactly one CV. It was not a catastrophic break and I still think it was a fluke. Run 35's with a nice low truck. When you break CV's every trip, start saving for CTM's. 1) Is ARB my only option for this waggy axle? 2) What are CTM's? I agree with running a nice and low truck for multiple reasons, but I can tell you that the main thing that hangs me up is high centering on my gas tank or my crossmembers. If I had an extra 4-6", it would make all the difference in the world, I think. Chris |
A Dana 44 has perhaps the widest selection of lockers available on the market. ARB Air Locker, Detroit Electrac, Detroit EZ Lockers, Detroit Lockers, Eaton ELocker, Powertrax Lock-Right, Full Spools, Mini Spools- 2) What are CTM's? http://www.ctmracing.com/ they build billet U-Joints My neighbor is running 1400HP thru CTM's on his alcohol blown Hemi. Yeah, It's got a Hemi in it! He had broken 1410's until he switched to CTM's |
A Dana 44 has perhaps the widest selection of lockers available on the market. ARB Air Locker, Detroit Electrac, Detroit EZ Lockers, Detroit Lockers, Eaton ELocker, Powertrax Lock-Right, Full Spools, Mini Spools- 2) What are CTM's? http://www.ctmracing.com/ they build billet U-Joints My neighbor is running 1400HP thru CTM's on his alcohol blown Hemi. Yeah, It's got a Hemi in it! He had broken 1410's until he switched to CTM's Chris |
Cool! I'll check them each out and make my decision. Do you have any recommendations?So, are these CTM's for my CV's as Adrian put it, or is this for U-joints for the D44 as their site mentions? I'm confused!
Chris That said, I've gone to a full spool. A spool is cheap and bullet proof, but turning raduis suffers greatly. I will be getting a hydro assist system shortly to help with turning the pig... Oh yeah, I forgot, the Ox Locker is available for a D44 The CTM's are for the Dana 44... |
Thanks again for the input! So, I guess all I have to decide is which selectable locker would be the strongest and most reliable.
Chris |
What rig is this going under?
Are you going to run leafs? |
Are you going to run leafs? Chris |
It's going to go under my 1997 4runner, and will probably be leafs, but would love to run coilovers, ideally. I haven't seen one done with coilovers, though.
Chris |
Originally Posted by dragr1
Go for it Chris! Have it done by the end of the month!
Chris |
