Probably needs some more details:
Engine: 22RE K&N FIPK Nology Wires NGK plugs Thorley header Hi Flow Cat 2.25" piping Flowmaster 40 3 core Radiator (3.0 V6) Downey Flywheel (Uses 3.4 Liter clutch) Painless Wiring Hot Shot Aussie Locker in Rear Suspension: JD Fabrication T-1 Kit www.jdfabrication.com Deaver G57 Tundra leafs 8" RaceRunnerss in front 450# Eibach coils 12" RaceRunners in rear AllPro Shackles Downey Idler Brace Total Chaos Heim Steering AllPro 1.5" Wheel Spacers Energy Suspension Bumpstops in rear Armor: Protrux custom front bumper with skid plate www.protrux.net Protrux custom rear bumper with 4 point swing out carrier All Pro Sliders Bud Built Transfer Case Crossmember Protrux IFS brace Protrux engine cage/shock hoops Wheels/Tires: BFG 33x10.50 AT's 15x7" Toyota Tacoma Alloys Body: Hannemann Ivan Hood and Fenders www.hannemannfiberglass.com Hannemann Bolt on rear flares Other: All Pro Disc Parking Brake conversion Masterflow compresso under the hood 48" hi Lift 2 100 watt Procomp spot lights Coming soon: Marlin Crawler 4.7:1 Tcase gears ARB's Front and Rear Swaybars |
| All times are GMT -8. The time now is 04:54 AM. |
