Need a welder /4wd fab guy in phx
My bud has a hoop with 4 large Hella's on his 07 taco.
Well, after 2 yrs of vibrations........it broke off at the bolt on point at the frame. The frame of the truck is cracked Desert Rat said they can't do anything for him. He's sending me pics so i'll throw them up later. Anyone got someone good in the PHX area? Thanks , Kenny S> |
e mail me pics at cpizzle42@yahoo.com
Fabricator / Yota mechanic needed in Phoenix
My buddy needs his light bar re-attached and new brackets installed.
He's got a late model Taco and both aluminum tabs broke off of the bumper frame on the truck. I'm guessing a steel tab between the chassis and the bumper frame for the light bar to re bolt to. Light bar also needs end to be heated and bent back into stock position. Southeast valley preferred.....Tempe/ Chandler/ Gilbert Kenny S desertrunner67@hotmail.com |
Need A rm bushings pressed in Phoenix? Do you know a spot?
Hey Guys,
I'm ready to pull my A-arms on my 99 runner and need a shop to press them out and the new ones in. I'm in Phoenix AZ............anyone know a shop or private citizen? Thanks, Kenny S> |
Thanks, where would I get a set of Control arm bushings pressed in in the phx area?
Kenny |
Sonoran steel is a no go on pressing the bushings
I referred you to Steve for the fabrication work/welding.
Check with Toyo motors for the rest of your needs http://www.toyomotors.com/ OR most any 4x4 shop. |
I can also do the bushings in my garage, just did some 3 weeks ago on a 97 4runner.
Is Steve only doing work on 3rd gen and newer runners? I was thinking about using him for the extra material on the axle for the locker swap and an interior cage for my 91 runner.
Originally Posted by mlrtime99
(Post 51396129)
