Help with body lift..;.
You use a block of wood and 2 hilifts to pick it up off the frame. You put the jacks under the front between the front doors and wheel wells. just make a few clicks and there is plenty of room. Then lower it and move the hilifts to the rear and do the same. I don't thint there was any debts as a result with mine.
I don't have a problem getting my Hilifts to release. They are extreemly hard to move at first but these have been well used.
I can remove the interior in a couple minutes to access the bolts through the floor so that's no biggy. I have all the tools needed in my truck right now.
i guess if you used a block of wood it should be ok, i just dont like hilifts. I supose since the body is light compared to a whole truck it will disengage easier. to each his own, as they say
#27
its always work..........just installed 2 6.5's and a clarion 4 channel and my alpine behind the removable storage pannels in the cargo area. now need to make kick pannels for some front 6.5's, then driveshaft, then e-locker install with 4.88's which need to be purchased and installed, then some rear springs/shocks/upper and lower links, then maybe then i can be part way done with my 4runner
EatChipsNow
Sep 9, 2015 01:25 AM
zz_denis
Sep 6, 2015 03:43 PM
justdifferentials
Sep 5, 2015 06:52 PM
LJR
Sep 5, 2015 06:02 AM
Badfish740
Sep 4, 2015 04:21 AM
