Powering Home Electronics Using a Car Battery????? - YotaTech Forums
Off Topic Talk If it's non Toyota & tech related, put it here
LinkBack Thread Tools Search this Thread
Old 08-31-2004, 05:19 AM   #1
ugadawg95's Avatar
I have seen some folks at tailgates that use regular car batteries to run a TV and Sat receiver. We have been doing so with a generator for about 3 years now, but this year I want to try something different. How would I go about using a car battery to accomplish this? I am guessing I would have to get an inverter and do it that way, but the battery will eventually die down and I have no way to recharge it unless I keep switching out one battery from the car with the one powering the equipment. is there any other way to do this?
ugadawg95 is offline   Reply With Quote
Old 08-31-2004, 05:38 AM   #2
4Hummer's Avatar
A dual battery setup may work best, Make sure you use a Battery Isolator that way you won't drain your "start" battery. You can pick up decent isolators from any RV center.
Run the invertor off the second battery,
Just my two cents...
4Hummer is offline   Reply With Quote
Old 08-31-2004, 07:55 PM   #3
OneTrickToy's Avatar
I've got a crappy inverter, only 140watts(but free). I have the inverter mounted under the hood. It's powered remotely by a switch on my dash. I've got wires running from the inverter to an outlet on a lower section of my dash(below where the old speakers were, it's black). When I get a better inverter I'm going to run romex wires and I'm going to put a second outlet(outdoor style with waterproof cover/seal) at the back of the bed. Here are the pics. Oh yeah, don't mind the cable ties holding the inverter. It's just a temp. setup until I get a better inverter.
OneTrickToy is offline   Reply With Quote
Old 09-01-2004, 08:52 PM   #4
in our quad trailer weve got a sweet setup. Me and my dad built a bathroom in it and put lights in and stuff. To power it we use a 2500 watt inverter hooked up to 6 golf cart batteries. We used the golf cat ones because they are deep cycle and last a long time. The batteries are only 6 volt though so you have to hook 2 up in series and then hook them to the next series in parrellel. Anyways it works good and the batteries are charged by my dads truck when we are pulling it.
terky is offline   Reply With Quote
Old 08-01-2008, 02:09 PM   #5
Use JUMBO High Power Battery its better then one you can find it and Appliances store and any general store...you can also buy from jumbobattery.com..
milino is offline   Reply With Quote
Old 08-01-2008, 04:23 PM   #6
Phssthpok's Avatar
Read and learn, padawan.
I would recommend a Pure Sine Wave inverter if your primary loads are going to be electronics. Square, and Modified Sine Waves can induce signal 'noise' in home entertainment electronics.
Phssthpok is offline   Reply With Quote
The Rebuild of Lucy. 1982 4X2 Standard Pickup jasonty Pre 84 Trucks (Build-Up Section) 38 10-05-2016 02:17 PM
Its beginning to look a lot like a head gasket?! (overheating) the1998sr5 95.5-2004 Tacomas & 96-2002 4Runners 13 01-11-2016 09:55 PM
87 22R hi idle not kicking down until... luckypig44 Newbie Tech Section 4 07-19-2015 11:25 AM
22r Loss of Power and Clicking. cars-guy Pre 84 Trucks 1 07-11-2015 07:51 PM
2000 camry wont start Huntingtruckcletus Other Makes Cars/Trucks 0 07-08-2015 05:26 PM
Tags
batteries, battery, car, duron, electronics, home, inverter, portable, power, powering, receiver, rig, run, start, tv
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
