CB transmits but doesn't receive: ideas? - YotaTech Forums
Off Topic Talk If it's non Toyota & tech related, put it here
LinkBack Thread Tools Search this Thread
Old 09-29-2003, 05:17 PM   #1
jimrockford's Avatar
I just tested my CB. I thought it was totally dead, but a friend was able to hear me transmitting loud and clear. I couldn't here him at all. I didn't even hear static. The weather function works fine, though. Any ideas?
We were sitting about 25 feet from each other. He was definitely transmitting as other people could hear him. Mine didn't pick up a thing, even with the volume all the way up, and the squelch all the way down.
My CB is a Cobra 18 WX ST with a crappy Cobra magnet mount antenna.
jimrockford is offline   Reply With Quote
Old 09-29-2003, 08:41 PM   #2
I'll assume you've double-checked and tried all the controls and made sure that there aren't any really dumb things you've overlooked. You said you tried the squelch, so I assume that means in both directions.
One possibility is the mic switch, element, or broken mic/cord wire. Are there any signs the CB is stuck in tx mode even with your mike switch open? If the radio is stuck in tx mode, you won't hear anything.
If someone else has a Cobra mic, you can try substituting that to see if it works. I don't know the age of your radio, but broken wires in mic cords are pretty common from what I've read.
I doubt its your problem, but I have a Midland and it came with the wrong mic because they switched wiring at some point and it exhibited similar symptoms.
You should be able to receive something with nothing more than a wire stuck into the center pin on the antenna connector in the back so even a crappy antenna should let you hear something if only noise. There is always some noise as far as I can tell. Can you connect your CB to someone else's antenna to see if it works. Unless you're pretty sure it isn't stuck in tx mode, I wouldn't advise the wire in the center pin for fear you'd have a reall high SWR and burn out the tx transistor(s).
If you can't get it to work with a different antenna and a different mic, I'd say its time to take it into a local shop. They should be able to tell you real quick if its the radio or the mic.
Alan
alanh is offline   Reply With Quote
Old 09-30-2003, 05:27 PM   #3
That's an excellent suggestion. I hadn't thought of the mic being stuck in TX. I'll test that tomorrow at work. Thanks for the help.
Yeah, I did check the simple stuff. I tried the squelch all the way up, and down. Everything seemed fine. I even took the radio apart to see if I could see or smell anything burnt. Again, it looked like new. I didn't give the mic much thought, though.
I don't have another Cobra mic to try, but I assume if i just speak into it without pressing the button anyone around should be able to hear me, right? Hmm, that's kinda scary. I'm glad I don't drive around with my CB on all the time. Sometimes I like to sing along to the radio as I drive...and that ain't pretty.
Help Diagnosing Random Stall _Nicco_ 86-95 Trucks & 4Runners 14 08-28-2015 07:26 PM
Roll bar fabrication DrZero General Vehicle Related Topics (Non Year Related) 18 07-24-2015 11:31 PM
87 to 89 22RE swap GeoRoss Newbie Tech Section 9 07-24-2015 03:03 PM
Troubleshooting my 1993 22re PlayAwhile 86-95 Trucks & 4Runners 5 07-20-2015 11:36 AM
One dash light doesnt work sometimes Jake28296 86-95 Trucks & 4Runners 5 07-12-2015 10:15 PM
Tags
18, cb, cobra, doesn, ii, radio, receive, receives, recieve, recieves, st, transmit, transmitfarreceivebadcb, transmits, wx
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
