Anyone taken the Caliper personality test?? - YotaTech Forums
Off Topic Talk If it's non Toyota & tech related, put it here
LinkBack Thread Tools Search this Thread
Old 07-12-2005, 12:57 PM   #1
Lotus1's Avatar
The Caliper assessment tests are used for employers to test how compatible a candidate is for a job and company they are applying for.
Has anyone taken one of these? I'll be administered one tomorrow, just wondering if anyone has gone through it.
link to Caliper online...
http://www.calipercorp.com/solutions...aliper_testing
Thanks.
Lotus1 is offline   Reply With Quote
Old 07-12-2005, 01:40 PM   #2
shiftless89's Avatar
Yep, also have taken the DISC placement and a whole battery of industrial profiling. Just be honest and answer the test with your first instinct. don't try to answer it they way you "think they would like" it quickly shows you are faking and is a quick turn off for employers. I've given them and taken them.. bottom line be honest
shiftless89 is offline   Reply With Quote
Old 07-12-2005, 02:09 PM   #3
iGGz's Avatar
I've takin it I think if its the same thing... I had to take it on a computer in some room...
One question was like:
"If your brother stole something from this store would you turn him in?"
I said no... lol asked same about a friend and I said no still...
They called the next week and asked if I wanted the job... so try not to lie to sound good like shift said...
Ian
iGGz is offline   Reply With Quote
Old 07-13-2005, 07:42 AM   #4
2ToyGuy's Avatar
I would, but since I have no personality, what's the point?
2ToyGuy is offline   Reply With Quote
Old 07-14-2005, 10:04 AM   #5
Lotus1's Avatar
Took the test yesterday. There were 2 sorta' tricky sections dealing with determining analogies and logical thinking.
This was one of the easier questions...
Choose the correct logical selection:
* 23: 3,983
* 32: ?
A. 3,839
B. 3,994
C. 4,874
D. 9,599
Thanks for your comments.
Old 07-14-2005, 10:42 AM   #6
iGGz's Avatar
Yeah I guess that isnt the test I took... it didnt have any analogies or any logical thinking... how long did it take?
Old 07-14-2005, 11:19 AM   #7
Lotus1's Avatar
These tests typically aren't timed. It took me about 1 1/2 hours. Longer than I expected.
Approx. 200 questions. Each of the questions definitely made you think too.
Old 03-21-2008, 03:07 PM   #8
* 23: 3,983
* 32: ?
A. 3,839
B. 3,994
C. 4,874
D. 9,599
Is it B. 3,983+11 ?
pgb205 is offline   Reply With Quote
Old 03-20-2009, 01:24 PM   #9
Finally got the answer ... but too late!
When I learned I was going to take the Caliper test I hit the net and discovered this thread. Lotus's description of the question he posted as "easy" nothwithstanding, I was unable to figure it out and unfortunatley the correct answer was never revealed. Sure enough the same exact question was on the test I took yesterday and I still couldn't figure it out. However, this morning I think I finally got it.
The answer is D.
23 is the sum of the numbers 3,983
32 is the sum of the numbers 9,599
Well, better late than never!
Here's the other one I couldn't get yesterday but figured out today:
A F Z U G L T
What's the next letter in the pattern?
1) O
2) C
3) X
4) N
If anyone else wants some help/advice on Caliper, feel free to ask while it's fresh in my mind!
askbigbird is offline   Reply With Quote
Old 03-20-2009, 07:16 PM   #10
leebee's Avatar
and all this proves exactly what? maybe im missing something here but i cant quite figure out why it really matters which letter is next in the sequence or the reasoning behind the numbers and how it will affect my job performance.
i applied at the orange box for a p/t job while im in school, had to do a similar test. im a cabinet maker applying for a job in the lumber/millwork/kitchen dept. do i really care about that stuff? does the customer really care either?
sorry for the rant, but its getting to be you require a phd for a bloody part time job for minimum wage!
lee
leebee is offline   Reply With Quote
Old 03-21-2009, 10:25 AM   #11
Caliper is a personality test. It's designed to help employers determine whether an individual's personality is suited for a particular job. It's merely a tool in the interview process.
The "pattern recognition" questions like the one posted are used to determine ability of abstract thinking. There are certain jobs in which being able to think "outside the box" is particularly desirable.
The pattern recognition questions make up only a very small part of the test. Most of the questions are quite different.
You can "rant" all you like but Caliper's been in use for over 40 years and it's not going away. Nor are other, similar tests. Used correctly, they can be valuable.
Incidentally, I took a different personality test many years ago when I applied for a job. The results said hiring me would be "risky." They hired me anyway and I worked there for 16 years. So I guess the "risk" paid off!
Old 03-21-2009, 11:52 AM   #12
leebee's Avatar
thinking outside the box eh? sounds more like they are looking for experience(d) folks. i used to get in trouble 'abstract thinking' when i was in school, they called it 'daydreaming'. man, if only i had known then...
lee
Old 03-21-2009, 03:02 PM   #13
aviator's Avatar
Quote:
The answer is D.
A F Z U G L T
1) O
2) C
3) X
4) N
answer is 1 "O" the pattern is 5 letters forward 5 letters back... had to think about it for a min.
aviator is offline   Reply With Quote
Old 07-20-2010, 08:04 AM   #14
Answer to a question
[from another user]
A F Z U G L T
1) O
2) C
3) X
4) N
If anyone else wants some help/advice on Caliper, feel free to ask while it's fresh in my mind![/QUOTE]
[Answer]
The answer is 1) O
The reason is F is 5 letters after A, U is 5 letters before Z, L is 5 letters after G, O is 5 letters before T.
hyperbolts is offline   Reply With Quote
The Rebuild of Lucy. 1982 4X2 Standard Pickup jasonty Pre 84 Trucks (Build-Up Section) 38 10-05-2016 02:17 PM
Joe.lit's 84 ish build up Jcrawl94 84-85 Trucks & 4Runners (Build-Up Section) 10 10-24-2015 04:34 PM
Front brake uograde garagespace 86-95 Trucks & 4Runners 10 10-11-2015 10:59 AM
test JUICE222 Post Your Tests Here 0 08-21-2015 05:16 PM
FS[GreatLakes]: Toyota collection part out 88sasturbotoy Axles - Suspensions - Tires - Wheels 2 08-11-2015 01:56 AM
Tags
200, analogies, answers, assessment, caliper, calipers, irg, like, online, personality, question, questions, test, testing, wikipedia
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2017 InternetBrands, Inc.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
