rocket01 |
01-26-2017 03:53 AM |
Why????
so, I have an issue with my rear window, here's what I have figured out thus far-rear window motor works if pwr supply direct-4 relays ( I believe) are good (I can hear click)- master door switch good- NO pwr. gettig to motor- tried the wiper motor jump with no luck-wiper works and is in park position-have not removed center switch yet to test---- NO pwr at 20A fuse for defog-NO pwr at 15A fuse for (brain fart-top right)-NO pwr at 2nd right down relay--master window switch is being powered by hot lead from fuse box/// should be the blue&red wire (hot) yes or no?---replaced 30A fuselink at motor- inside of truck is trashed trying to find problem, any help would be appreciated. ty
