YotaTech Forums
-   Post Your Tests Here (https://www.yotatech.com/forums/f4/)
-   -   Test (https://www.yotatech.com/forums/f4/test-157355/)
mt_goat Oct 22, 2008 04:01 PM
Test
Getting ready to have a custom exhaust system built from the cross-over back. I couldn't find anyone that sells a Toyota O2 sensor bung to weld into the new exhaust piping. After talking to a friend that works at the local Toyota dealer about where to get one, he says why don't you just make one? I hadn't thought of that Jason, thanks for the idea. So here's how to make your own O2 sensor bung.
I started with a piece of 3/8 steel and marked the outline with a gasket and drilled and tapped some holes (8mm x 1.25):
http://inlinethumb38.webshots.com/15...600x600Q85.jpg
I used some exhaust studs from the dealer that were left over when I was putting on the ORS cross-over.
http://inlinethumb60.webshots.com/30...600x600Q85.jpg
Then I started cutting it out with a cutoff wheel on an angle grinder:
http://inlinethumb04.webshots.com/13...600x600Q85.jpg
After using a grinder and beltsander to smooth it out:
http://inlinethumb40.webshots.com/29...600x600Q85.jpg
Now that was one bung, but I need two for the 5VZ right. The first one took me about 2-3 hours to make so I decided to try cutting an old one out of my old 3.0 exhaust pipe and using it. That took about 2-3 hours too, counting replacing the old studs and smoothing it out with a grinder and beltsander too.
Here's the two side by side, the one I made from scratch will have to be welded in parallel to the pipe since it's not curved to the shape of the pipe:
http://inlinethumb57.webshots.com/38...600x600Q85.jpg
http://inlinethumb08.webshots.com/81...600x600Q85.jpg
