Replacing the Timing Chain Guide on a 22RE Engine
This is how I replaced the driver's side timing chain guide on a 22RE engine without removing the timing chain cover. It is not as hard as you think. Please keep in mind that the description below is based on my own experience only and is not intended to be used as professional advise.
This is what I used:
Removal
Installation
Did you replace the tensioner when you replaced the guide? They're usually done as a set, along with the chain. So two guides and a chain are replaced all together. I am no professional mechanic by any stretch, but that's my understanding. I may well be wrong though.
Just being curious. Other than the above, good write-up. Pat☺ |
Very likely that a stretched timing chain broke the guide, and your Houdini guide job won't last long. Ingenoius though.
I only replaced the driver's side guide. To replace the tensioner, timing chain or passenger side guide, you would have to remove the timing chain cover.
I really like the creativity behind doing it this way, but I'm going to have to agree that the chain, both guides, and the tensioner should be replaced at the same time. Otherwise cool write up.
| All times are GMT -8. The time now is 10:35 PM. |
