link test
moved below in signature
when you did the hyperlink you had https://www.yotatech.com/wwwbrian894...osanddiff.html
http://www.brian894x4.com/ correct link is below: http://www.brian894x4.com/Gearratiosanddiffs.html |
I found that out ,I am trying to learn how to add links and other things .The problem is that i am not very good with computers. Thanks for the help i will try again.
-copy the link you want
-type out what you want the links to say: Brian's Diff info -High light that -click on the hyperlink icon -you will get a pop up to insert the link, you might need to disable/allow pop up if you have a blocker, paste that in and you should end up with this: Brian's Diff Info |
| All times are GMT -8. The time now is 02:51 AM. |
