Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
LCE Head gasket kit
Old 02-16-2018, 05:13 AM
Dismal's Avatar
LCE Head gasket kit
Hi everybody. It looks like i need to do a head gasket on my '87 22re. Not entirely decided yet, but i'm doing some research anyways.
I've heard nothing but good reviews on LCE's products. my question is the head bolts.. with my motor being all stock, would you suggest $25 oem head bolts or are the others really worth their money?
Old 02-16-2018, 05:16 AM
Dismal's Avatar
Any info/suggestions would be much appreciated. thanks in advance!
Attached Thumbnails LCE Head gasket kit-screenshot-3-.png   LCE Head gasket kit-26771855_10210996068565404_1181563413_o.jpg
Old 02-16-2018, 08:20 AM
gsp4life's Avatar
If you're deciding between standard head bolts vs. arp studs on a stock engine, I vote for saving your money. Just clean the mating surfaces and bolt holes really well after chasing the threads, use the correct torque sequence to 65 ft/lbs, and you won't ever have an issue.
Studs can be useful on engines with power-adding mods that put extra stress on the head gasket interface. Turbo's, aggressive cams, stroker, etc.
Old 02-16-2018, 09:55 AM
Dismal's Avatar
that's about what i was thinking. apperantly the studs are also reusable which i guess is neat, but once i put a head gasket in i'd like to think i wont have to do it again. OE bolts it is. thanks!
mountainbrew
06-26-2017 09:07 PM
bone collector
12-14-2013 01:34 PM
Relyks
04-04-2012 09:32 PM
sas'd22re
08-31-2009 10:06 PM
YotaTruck1986
07-29-2004 09:08 AM
Quick Reply: LCE Head gasket kit
