YotaTech Forums
-   Post Your Tests Here (https://www.yotatech.com/forums/f4/)
-   -   95 pickup 22re (https://www.yotatech.com/forums/f4/95-pickup-22re-315664/)
Dfarmer Jun 14, 2022 10:51 AM
95 pickup 22re not starting??
I had a 22re locked up so I swapped it out with a 80s 22r I had and took the intake off and went with the fuel injection.. ran great drove to work and it cut off blew the am2 fuse. Ever sense it will intermittently have fire.. sometimes when it does have power will run for a minute or so and cut off
Things I’ve checked. Fuel pump,spark plugs, plug wires,all the fuses, timing,all my grounds.everthing checked out
things I’ve changed.. igniter, coil,injectors,distributor,plugs,wires,ecu,mass air flow,knock sensor,
