22r Idle issue and sputters
Hey guys I'm new to the site but it has helped me a lot over the years with my toyotas. So any ways I'm gonna try to not make this to long, and I have searched for similar problems on here and can't find a straight answer. I have an 87 pick up with a 22r 5 speed and lifted 4 inches. The truck has a small sputter when running and can defiantly tell it is running rich. It also dies / floods when coasting to a red light. Here is a list of new parts I have put on or checked recently.
NEW PARTS: Motor is brand new and has less than 1k on it. Weber 32/36 Fuel lines ( not metal ones to tank) Fuel pressure regualtor set on 3 psi New fuel pump New spacer plate for carb PVC valve Hooker headers and new exhaust all the way back Alternater Starter Master cylinder and booster Intake gasket Plugs ( correctly gapped) Cap and rotor Wires Relatively new ignition coil Has 0 vacuum leaks and the only vacuum lines hooked up are for advance. i have de smoged the truck best I can without taking egr off because I don't have a plate yet. Truck runs pretty decent other that the sputter and dies when coasting to red light. I have played with idle and air fuel screw a good bit and have always been pretty good with carbs but for some reason I can't figure this thing out any help I would greatly appreciate it. By the way truck is in decent shape. Brand new 4 Inch lift and has 33s under it. I will get a video of the truck running tomorrow so you can better understand what is going on. Thanks again guys.https://cimg2.ibsrv.net/gimg/www.yot...241217e5d.jpeg https://cimg5.ibsrv.net/gimg/www.yot...8c10d50c3.jpeg https://cimg0.ibsrv.net/gimg/www.yot...74851bdfa.jpeg https://cimg4.ibsrv.net/gimg/www.yot...69fd1acbe.jpeg https://cimg8.ibsrv.net/gimg/www.yot...4f7ee5070.jpeg |
