Ruffstuff 3 Link Kit!
FormerVendor
We have here everything to create a 3 link suspension, front or rear, and not low end stuff just to be cheap either! The kit is wrapped around 6 of our 1.25" Heat Treated Chromoly Heims with Zinc Plate or Stainless Steel High Misalignment, Zinc Plated Jam nuts, and 1.5" Tube ID Weld Bungs. You also get another set of Heim joints in 7/8" for the Panhard. You get our Chassis Link Brackets and 10 Degree Axle Brackets for the lower arms. Then a choice of Upper Link Tower at either 0, or 10 degrees left or right. Again you have a choice of 0, or 10 degrees for the frame side 3 Legged Bracket to finish it off.
We finish the Kit off with your choice of Pan-Hard Brackets. We offer two styles for the Frame side, and 2 styles for the Axle side, each with (3) 9/16" Bolt holes so that you have an easy time making the geometry work.
You can choose to order the kit with or without tubing because you will often save a lot of money buying your tube locally when you add the shipping cost of the tube, 2" x .25" wall DOM weighs over 4.5lbs a foot!
If you need to change anything give us a call and we can mix & match til its right for you! We do have DOM as an option but always price it locally first...
