I've got the prototypes made for the passenger side 22re and the 2.7 mounts made...should be ready soon :D
Hey
hey how do i go about getting one of these brackets form you!
Passenger side 22RE mount ready yet?
Originally Posted by AZ4ME
(Post 50862187)
ready to ship ! :)
do i use my toyota belt?
You should make one using the Ford 3G style alternator. They produce at least 130 amps or more and they seem to be more reliable than the GM ones.
James |
Originally Posted by bigt
(Post 50896302)
Yes..you use the same belt |
Does this work on a 20r?
Do you simply install the GM alt and run a wire from the alt to the + battery post? |
Originally Posted by Malchick
(Post 50948174)
Do you simply install the GM alt and run a wire from the alt to the + battery post? for a single wire alt. The best way to do it in my opinion is to run a 4 guage wire from the batt. terminal on the alt. to a fuse/breaker then to the battery then take the stock wire that went to the alt. and connect it to either side of the fuse/breaker (wire is already fused within the stock harness) if you need any other info let me know |
Sent you a pm.
Kyle |
Aaronn
Sorry But I’m a little mechanically challenged and need things spelled out, simple like. As you can see I have an 87 pickup with 22r Carburetor and AC. I want to upgrade the alternator for all the extra crap I like to have. That being said, Will your bracket work for me? If so how do I get one from you? Exactly what GM unit do I need to buy? Will I need to modify any wiring? Can you give me detailed installation instructions? When I click on “GM single wire alternator brackets, Click here” it takes me back to the start of the thread. So maybe I’m computer challenged as well. Thanks, Scott |
Originally Posted by SEMSD
(Post 50980521)
Aaronn
Sorry But I’m a little mechanically challenged and need things spelled out, simple like. I'm PMing you my phone # |
hey just found your thread while cruisin around, me and a couple buddys are interested in the brackets for our 22re's. how do i go about ordering them?
jason |
Originally Posted by 81YOTACRAWLER
(Post 50988963)
jason |
Aaron
Are you still making these?
Please send me your contact information. I"ll PM you my email address. Thanks!! |
Originally Posted by Land yacht
(Post 51027164)
Please send me your contact information. I"ll PM you my email address. Thanks!! yep...still at it :D |
aaron, can you email me your contact info please? i'd like to purtchase this bracket. i dont frequent this site so a private message might get overlooked... please email me at: lucky_brewer@comcast.net thanks
OUT OF STOCK UNTIL NEXT MONTH .......sorry
