Winching with an Automatic Transmission
I recently added a Warn m8000 to my rig and I've read the manual and a lot of stuff online but what seems to be missing in all this info is what gear you should be in when recovering another vehicle. Do you want to be in drive with the foot on the brake (or ebrake on), or in Park? I really think being in park would not be the wisest choice and would be hard on the tranny.
Any insight? John |
It depends. For really light duty stuff, park and ebrake are fine. But if there is a risk of you being pulled forward, then neutral with you standing on the brakes is the safest for the equipment. Drive is a safety concern.
Excellent question.....and I'm not sure of the answer. I only had to assist in the recovery of a couple of vehicles with my winch (usually I just tug them out with a snatch strap). I kept the transmission in neutral, emergency brake on, and foot heavily on the brake. I'm very interested in seeing how some of the more experienced members respond.
James |
I defer to Rob's 517 years of off-roading experience for the answer, but one thing to point out is the difference between the e-Brake and standing on the pedal...
Remember that the e-Brake only locks up the rears which are drums in most of our cases, whereas standing on the pedal will lock up the rears AND the fronts. |
In neutral with your foot on the brake.
Don't use the e-brake as your rig may still get pulled forward. If it's a really heavy pull then tie your rig off to a tree or 2nd rig. |
Originally Posted by Yota Tony
(Post 50489736)
All of our hydraulic winches at work require Neutral, e-brake and standing on the brakes (or so sayeth the transport guys).
If we're winching really heavy stuff, we normally chalk the wheels and stand on the breaks...you ain't moving. |
Originally Posted by WATRD
(Post 50489739)
There can damage due to frame stretching/tweaking if that is not done right...
Originally Posted by Bill
(Post 50489744)
True, but if you're pulling something that is THAT stuck as to bend your frame, your best bet is to get a 2nd vehicle to help and/or a truck with a bigger winch.
When I had friends' TJs winching out my stuck Grand, most the time they had to tie off to something. This was mainly because my Grand weighed around 5000lbs. Some time they had to do a double line pull. It depends on the rig doing the winching and rig being winched. |
The last time I had to be winched out, it was by a TJ. I was stuck pretty bad and couldn't come out from the front, so we rigged up a pulley so that he could be in front of my truck yet winch from the rear. We had to attactch his truck to a tree and a guy that was watching said that when he started winching me out, his tires were actually lifted off the ground as it pulled.
Originally Posted by Ric
(Post 50489794)
a quick search online provided lots of info:
http://www.truckstuffusa.com/witeandhowto.html http://www.offroaders.com/tech/winches/winch5.htm http://www.superwinch.com/support/le.../trailers.html Corey (i think its him) has a great write up on winching. John |
Do not put the vehicle in Park!
Reason being is the parking pawl which pivots off of two bosse's cast into the transmission case, and when in Park position, the pawl locks into a drum in the geartrain. If enough pressure is applied to the pawl, the pin which run's through it and into the bosse's, will break the bosse's off, effectively breaking the transmission case. Park will no longer work. Costing you a transmission R&R, stripdown, a new transmission case, and reassembly. Not cheap, been there done that with a Chevy TH350 years ago. If you can pull your vehicle, [ the winching vehicle ] up to a tree, stump, or rock, let the bumper roll into and rest on the tree/stump/rock, and pull the other rig that way. Without using park, just lock up the brakes. |
(Post 50489739)
Ideally, you never attach the rear to something when winching. A safer bet from the perspective of frame damage, is to secure the front bumper either by putting it against something or by attaching your anchor to it. That way the added load down the frame is zero.
Now, if you have a truly rigid winch mount that bridges the fronts of both frame rails solidly and you have a bumper or hitch in the rear that bridges the rear of the frame rails solidly, you are minimizing your risk. However... there is always a risk when you secure the rear, then load the front. If you get shock loaded or even worse, shock load from an angle, the frame can get tweaked from a rectangle into a parallelogram. The level of damage all comes down to the force exerted and the rigidity of the bumper/mounts. Sometimes the damage is slight, sometimes your rig will crabwalk forever more. |
I should also mention that anchoring dead center in your rigid rear mount will also help reduce the risk. Loading one corner in the rear, when winching in the front increases the risk.
Originally Posted by Mojo_Risin
(Post 50489817)
Well thanks for the links (i've read them all) but none of those talk about putting your truck in gear or in neutral, etc when recovering another vehicle. It's wierd that no one address this issue.
John Re "double line pull": Don't forget your clevis and snatch block. A snatch block doubles your winches power. |
I don't agree with the reversing method while winching another truck.
The winch clutch isn't meant to support that kind of forces neither the winch cable. I've seen people doing very stupid things with winches like using the cable as a tow strap and things like that... Winch is a "double sharped weapon" as we say in Spanish, it can get you unstuck or can be a nightmare if you don't use it properly. Please be careful with winches! David |
Originally Posted by Blizzard
(Post 50497692)
The winch clutch isn't meant to support that kind of forces neither the winch cable. I've seen people doing very stupid things with winches like using the cable as a tow strap and things like that... Winch is a "double sharped weapon" as we say in Spanish, it can get you unstuck or can be a nightmare if you don't use it properly. Please be careful with winches! David x2 - I would rather treat my winch well than have to replace winch parts - and a sure way to be replacing winch parts is to be adding uncontrolled vehicle force to it! |
(Post 50497692)
The winch clutch isn't meant to support that kind of forces neither the winch cable. I've seen people doing very stupid things with winches like using the cable as a tow strap and things like that... Winch is a "double sharped weapon" as we say in Spanish, it can get you unstuck or can be a nightmare if you don't use it properly. Please be careful with winches! David I agree, I actually work at Warn Ind. and have alot of experience around the testing of winches and stuff like that, plus a little off-roading experience of my own. NO REVERSE when winching someone else out, it can add more load than you winch is capable of handling, plus it can put more stress on your bumper which could break it, snap it, bend it, etc... Like it was said previously, place your bumper up against a tree or something solid that you are positive wont move, and use that as your stopping force if the vehicle stuck starts pulling you in. OR, if you have a place on your bumper itself that is rigid and strong enough, you could wrap a tow strap around it, and anchor yourself behind your vehicle, keeping all your force on the bumper itself instead of stressing the frame. To do this, wrap the tow rope around the bumper, and drag it under your vehicle and anchor it well behind you. I've seen it done, but never done it myself. and it makes sense to me. As for your quesstion, no park, no gears, leave it in nuetral and use the foot brakes (and block them up if possible.) |
