YotaTech Forums
-   Offroad Tech (https://www.yotatech.com/forums/f31/)
-   -   torch (https://www.yotatech.com/forums/f31/torch-50444/)
Jared Ajlouny Jan 28, 2005 07:12 AM
torch
when im doing the sas im gunna need a torch, what kind should i get? would this one be any goood? i can get a brand new one from some guy for 200 bucks. after the tanks and gas it cost him 500! http://store.cyberweld.com/vipotowecuou.html should i get it or will it be a waiste? i need somehting cause i cant afford a plasma cutter yet. i know nothing about these, thanks !
WATRD Jan 28, 2005 07:48 AM
If you use a torch to remove the IFS components, be careful! That's a lot of heat near the frame. Folks do it all the time, but I chose to play it safe and use a plasma cutter for more control of what got hot.
Jared Ajlouny Jan 28, 2005 12:04 PM
i was gunna try to borrow a plasma cutter, and people i tlaked to said it would be way better with a torch since the IFS has a thick metal beam in the middle or something...
WATRD Jan 28, 2005 12:26 PM
I had no problems with a plasma cutter and since the heat is better contained, I could get closer, leaving less grinding :) I would recommend you go that route as well. Easy as cake ;)
914runner Jan 28, 2005 02:51 PM
I know next to nothing about plasma cutters but from the specs I have seen on most units, and the 1 time I have used one, pretty much any plasma cutter should get the job done.
crash Jan 28, 2005 03:31 PM
A plasma is nice (love mine) but for cleaning a frame of brackets, I suggest using a torch. The toyota frames are low carbon/mild steel, so heat will not affect the nature/strength of the frame at all..
One thing about the plasma, where you point, is where you cut. Using a torch, you will find that you can play with the heat thats aplied to part you are cutting, to remove it easier (hard to explain, but its a method I use on a regular basis)...
Jared Ajlouny Jan 28, 2005 05:31 PM
how much do you think the one that i might get is worth? will it do the job i am needing it for?
86toyota Jan 28, 2005 06:59 PM
If you plan on doing alot of cutting, your going to need bigger bottles. That is a great set for occasional cutting and heating up parts for removal. What's nice about those is you can exchange the bottles anywhere like a 20LB propane tank. When you go bigger, you are stuck with where you purchase the bottle from to get it filled usually. The bottles don't last long at all. They only cost about $8 and $12 to get filled thou.
Jared Ajlouny Jan 28, 2005 07:08 PM
online it says it cost 100 bucks for the bottles? its only 12?
86toyota Jan 28, 2005 07:25 PM
I Thought the bottles were included there. Forget that place and buy this one. Same stuff and includes the bottles for $219. You can only ship bottles empty. Then you have to go somewhere to get them exchanged for full ones. They don't fill those size bottles, only exchange them.
http://www.harborfreight.com/cpi/cta...temnumber=3395
