Tcase bearing question
Old Jan 1, 2024 | 01:33 PM
K5BEAST's Avatar
Any tricks to removing the rear counter shaft bearing? Service manual says to use tool number blah blah blah which I don't have.
85 4runner.
Old Jan 1, 2024 | 03:16 PM
millball's Avatar
Is this the bearing pressed to the shaft. or the bearing set in the case???
If it is the one on the shaft, a bearing separator plate and a press are required.
Something similar to this>>>
Old Jan 1, 2024 | 06:59 PM
K5BEAST's Avatar
No, the one pressed in the case. I got it. Only about 2/3 of it is accessible from the back side. I found a bearing race that matched the diameter, cut out the 1/3. Ended up with a crescent moon shape. Welded a plate on top of it and a long bolt. One good smack and the bearing popped right out.
May 25, 2010 12:46 PM
ronnny
Jul 30, 2008 04:43 PM
tntoyota22
Mar 3, 2006 06:55 AM
GoudyMan
Jan 9, 2004 03:18 PM
