Susoension options for toyota pickup
What's going, I'm new to this forum so hopefully I post this in the correct spot and I need some input on my suspension set up. I previously had an 06 taco 4x4 and was in the middle of upgrading my suspension to some whay midtravek level. I had total chaos uca and extended king coil overs. For the back I was planning on using total chaos sua leaf set up and the title it as mid travel as well. Before I could finish I lost the truck to a fire and I was fortunate enough to buy aother vehicle; a single cab 1990 toyota 4x4. I know the suspension systems are a little differerent but is there something relatively on the same level ? The options I've seen are either long travel ( which would be great but not enough funds) or rock crawler with solid axles swaps ( not the direction I want to go ). Ant input or suggestions would be great. Thanks
Read the FAQ section and check out the lift guide.
https://www.yotatech.com/forums/f116...-first-201994/ |
