a small lift
Does any one know of anybody who makes a 2 or 3 inch suspension lift i already have bj spacers and a 3 inch body lift. I dont want to lift my truck to the sky either with like a 4 inch lift i just want a couple more inches of wheel travel, i'm leaning more towards a 2 inch lift nothing really big.
thanks guys |
what truck do you have
well if you have bj spacers im going to assumore u have ifs which means all lifts are just bracket lifts which wont net u any more travel just the lift except for long travel but i dont think that is what u mean
i have a 1990 toyota extra cab with 33x12.5.15's and 4.56's
Get OME torsion bars then crank them up 2", then put an aal or 2" shackles or 2'' lift springs for the rear.
For more wheel travel on IFS, a long travel kit would be the only option (assuming no SAS).
i was thinking torsion bars also but is that going to really give all that much more wheel travel, wont it just lift me 2 more inches, and also about the long travel kit are you refering to like total chaos caddy kits? I dont think i'll do that cause its a little pricey but i checked out
I was just suggesting lift options. I don't think torsion bars give any more travel either. Yeah total chaos kits are a couple grand I think.
i run this set up
Donwey shock hoops dual bilstiens low pro bumps BJ spacers OME torsions it gives me a little more travel than stock (i'm going TC in the future) (Low pro bumps not installed in pic) http://www.imagestation.com/picture/...4/eb0588e8.jpg http://www.imagestation.com/picture/...0/eaddb306.jpg |
Originally Posted by chip
(Post 50506796)
thanks guys Torsion bars will not open the travel window, however, stiffer bars will allow you to use less of what travel you have when crawling. Frank |
where do you get low pro bump stops at i cant remember if i've seen those somewhere or not, but thanks alot guys you all have been a really big help i think i'm going to just a a shock hoop and those bump stops seeing that theres not alot out there that isnt rediculously expensive i appreciate the help though see you guys on the trail some time
one more thing, Norcalsvx can I see a picture of the lower half of the suspension. I saw where you mounted the shock hoop and the upper part of the shock but where do you mount the lower part. Maybe its obviouse if I go look at my truck but I just woke up
