ome shocks and stock springs ?
i was wodering if anyone has a 3rd generation 2wd 4runner with ome shocks and stock springs. i have heard that ome's are extended length and would not work with stock springs. is this true? any info would be helpful.
Is yours a 4cyl?
There was someone with a 2WD 4cyl that had OMEs on there and it got alot of lift from running the springs. The OME shocks are longer in the back but I beleive you can still run them with stock springs on-road no problem. .....if you start flexing I am not sure what would happen. |
Gadget |
MTL were you sying that he got alot of lift form the shocks with the stock springs or from the ome springs also. well i am not planning of doing any thing off road, and its not a 4cyl. so thanks for the info. guess i will order them soon.
