Need help
So i ordered the 2" basic lift kit from toytec for my 1992 toyota pickup short bed single cab 4x4 and the front went fine other then replacing some bad parts when i got the the back the roll pin in the leaf springs was a lot bigger then the add a leaf so i called toytec and the guy was like idk what to tell you, you should have read the description of the lift witch said** If your Truck has 3.25" ID rear Ubolts, this kit will not fit your vehicle **so now my truck is completely apart and don't know what to put back in or do so any ideas what to do i was going to just get all new leaf springs with a 2" lift on them but for some reason it says this product will not fit my vehicle so let me know what to do!!!!!
Drill the hole to the correct size if that is the only problem.
If you don`t have a drill press get some one who does to drill them for you Just where does a roll pin go into leaf springs?? Learn to read the fine print some lessons are expensive to learn!! You ordered the wrong part we all I am sure done the same thing. Either make it work or sell the parts you ordered wrong . Pretty easy :coffee: |
| All times are GMT -8. The time now is 10:45 PM. |
