more flex without lift? (bigger tires without lift?)
Originally Posted by Albuquerque Jim
I took the rear off for a short time and I could pull a front wheel off the ground while accelerating around a sharp turn, a little too scarry.
I disconnect the front if I feel like it. On the street it does feel tippy due to increased body roll.
so, it looks like no, don't disconect the rear.
Originally Posted by rocket
I made my own set very similar to these. (Steves are better) and the rear flexes like crazy.
i'm running 31 x 10.5 with no rub no lift on my 3rd gen like yours. you might as well lift it. it seems like the same amount of work.
I will probably get flamed for this, but, Chadbobb, before you go messing with your swaybars do some research. There are many smart people on this board (including myself) that find that disconnecting or removing sway bars buys you ZIP offroad, and increases lateral instability on the road. It's because (unless you use lockers), the wheel that hangs will not get traction by definition. What you will have gotten yourself is a low hanging spinning wheel on a tippy 4Runner.
My vote - don't do it. Figure out what you want to do with your truck and modify as needed.
#25
I would submit that disconnecting your sway bar is smart (so you don't break it) but there is little to be gained offroad. (YMMV - especially if you've put an aftermarket suspension on that allows for droop past manufacturers spec - i.e. longer shocks).
#26
My vote is to leave it connected. My reasoning is that if the sway bar is disconnected then you run the risk of bottoming out your shocks. Or even have a coil become un seated. I have yet to see it happen but I imagen its possible.
Plus, the 3rd gen flexes pretty darn good in the rear with just after market shocks and coils.
This pic was from before I put my johnny joint links in.
#29
I disagree. Obviously the more rear flex you have, the more level your rig will stay on the trails.
https://www.yotatech.com/forums/f2/fj80-shocks-sonoran-steel-lower-control-arm-flex-pics-80221/
yes...
http://www.sonoransteel.com/rubicon_express_links.html
yes...
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
