more flex without lift? (bigger tires without lift?)
Is there anything i can do to get more flex and not have to get a lift of any kind. I saw someone post about new shocks but i can't find that thread anymore, and I don't know if they included a lift with the new shocks.
Also, I have 265/75 R16, so i can't get any bigger as far as i know. But my friend has a ford F-150 and to get bigger tires all he had to do was cut a small piece of plastic from his bumper to keep it from rubbing. Is there anything like that? Or is the only way with a 4runner to get bigger tires is to lift it? Thanks. My guess is i need a lift for both, but maybe not |
You'll most likely need a lift for bigger tires. I'm not sure what's the biggest size tires you can fit under there w/o one, but I'm sure others will chime in on that. As for more flex, I think the Runner is IFS thus making it very limited. One option would be to do a SAS.
if you go 285.. even the most amount of trimming you do it will still rub the a arms without a lift real badly.. you need at least 2 inches
You'll need to either get out a sawzall and go to town, or lift it. An F-150 has larger wheel wells, the 3rd gen is going to need a bunch of trimming. Flex improvement will be small, but you can get a bit. Try some swaybar discos. A SAS? Be serious...the amount of money, time, and effort needed to do that for a guy asking for no lift? You can't do a SAS on a 3rd gen w/out some lift. |
you could put swaybar discos in (or take the swaybar out all together) no sway bar gives you quite a bit of more flex
Lower profile compression bumpstops will help too.
Note: you want the flex to be balanced between the front and rear. There is not much point to increasing the rear flex until you get the front moving... |
https://www.yotatech.com/forums/f2/fj80-shocks-sonoran-steel-lower-control-arm-flex-pics-80221/ http://i42.photobucket.com/albums/e3...x/361bb940.jpg
http://www.sonoransteel.com/rubicon_express_links.html |
Level does not necessarily equal stable. Keep in mind that the spring on the P.S. rear axle is doing nothing for you at this point, and I'm guessing that the D.S. front is in the air... The truck is level because the P.S. front and D.S. rear are on the same plane.
what is d.s. and p.s.
remember, im a noob |
Driver and passenger sides.
PM Ravencr (i think). Someone put on 285s and only had to do some minor pounding with stock suspension. Then they lifted the truck and ran into more issues (than when at stock height). I don't recall his wheel setup at the time. I don't recall if he trimmed the fenders, but I don't believe so. And I certainly don't recall what year or fender style he had.
Is the main problem with them not fitting width?
And what is the widest i can put on the stock toyota rims? 265? Edit, im just curious, why does lifting the truck let you put wider tires on it? doesn't make a lot of sense to me..... |
The wider the tire, the more fitment issues because of the "scrub radius" as the wheel turns. By lifting the truck, you put the wheel in the wider, lower part of the wheelwell.
remove swaybars
just take them off instead of paying for discos i took mine off and will never go back. one of the cheapest ways to gain offroad performance.
is it a big difference? does it make it less stable or just ride like crap on the highway? if its safe im fine doing that
unbolt the links (the part where it attaches to you're lower control arm, or a arm, and leave the bar hanging...It will clunk a bit, but see how you like the performance...you can then just reconnect them if you don't like it, and get disco's, but i think you'll be supprised at how little you notice it.
I hear of guys taking off the rear one too, so maybe try that if the front seems okay with out...some third gen guy would know better than i. |
I just learned something new, again. :shocked: |
avoid rubbing. dont step up tire size until your truck is ready for it.
you can ruin the tires, tear off body parts and cause a lot of stress by stuffing a tire too hard. |
i removed my rear swaybar, it doesnt do too much crazy stuff, i am lifted also, it doesnt lean much more if any,but i turn slow most of the time. i have had the inside front wheel off the ground pulling a quick u turn, i did not even know it untill i felt it sit back down on the ground. i was like, woah, cool. the cars around me didnt get that feeling i suspect.
I hear of guys taking off the rear one too, so maybe try that if the front seems okay with out...some third gen guy would know better than i. I disconnect the front if I feel like it. On the street it does feel tippy due to increased body roll. |
