long travel kit toyota t100
I am looking into buying a long travel kit for my 97 t100. ive looked at chaos fab, the blazeland lt kit. are there anymore out there? also, i need to keep 4x4 so i know i will need custom axle shafts for the front. what else would i need? what kit out there has the most travel? how about the rear axle what would i need to do to that, since what i have researched involves only the front. Really exploring my options before i buy, and i wanna know as much as i can before i do anything.
Aside from Total Chaos and Blazeland, no not really. To keep 4x4 you need to get the extended CV axles from Total Chaos to use with either the TC kit or Blazeland. Id go with the blazeland kit up front with a chevy spring swap for rear to keep cost low, plus the only other company I know of that makes a lift kit for the T100 is superlift, its a generic IFS drop bracket kit that doesnt give you to much travel up front and uses blocks in the rear. TC is good if you got that kinda money to spend.
DacodaYota
09-02-2015 02:13 PM
