Lift options for 94 4runner
I have a 1994 4runner auto 4wd. I dont have alot of money at all because i have to pay for my college. I have two options for a lift i have found. im am wantin to put 33x12.50 tires on and i want to have a good lifted truck.
Option (1) 3"-4" Lift (approx.) Sdori 1.5" Ball Joint Spacers (1pair) Sdori 2" Coil Spacers (pair) OME N98 Front Shocks (each) OME N72F Rear Shocks (each) OME 901HD Coil Springs (each) OME SD33 Steering Stabilizer Total $614.04 Option 2 3" body lift I figure ill regear for the 33" tires hopefully if i have money So the question is what option is better for my truck? which will give more lift? Which will look the best and will one make my truck look higher than the other? which will make my truck better offroad and on and more? thanks also what if i got both options the lift and coil springs and spacers and all? could i fit 35"? would it be like a 6-7" lift? also does changin the gears make a lot of difference in performance. |
