hidden snorkel PICTURES?
Hey everyone.
I have been reading lots about hidden snorkels on 2nd gen 4runners. There was several threads that covered this topic, some of which dated back to 2004. One thing each thread had in common was almost all of the pictures are no longer working. I would really like to see how some of you did your hidden snorkels!! Help a brotha out! :) |
1 Attachment(s)
You cant see mine because its hidden!
Attachment 201625 Its just a 2" shop vac hose, goes from the air box, out under the fender then back in the engine bay in the red circle. Theres a screen over that end to keep larger stuff out. No noticeable power loss, but a 3" hose would probably be better. |
Check to see if you can find 4crawlers hidden snorkel on his 85 4runner. The same concept would apply to your truck
Hint: 4crawleroffroad.com |
Mine is kinda hidden.
Wut???
@ rattle wagon, I like the idea. Do you ever have problems with taking water in?
@ drop zone, I will check this out as soon as I can. Thanks! @ big blue, take a picture! :) |
I did a write up
Originally Posted by ohoktimmyg
(Post 51903521)
Heres one with PVC, Sort of like mine but not sucking from the engine bay http://www.offroad-nw.com/contents/t...o%20fender.JPG |
(Post 51903406)
http://i179.photobucket.com/albums/w...Photo563-1.jpg Its just a 2" shop vac hose, goes from the air box, out under the fender then back in the engine bay in the red circle. Theres a screen over that end to keep larger stuff out. No noticeable power loss, but a 3" hose would probably be better. |
Sure, ill get some pics next weekend. I just siliconed the hose into the inlet tube of the airbox. When Im not using it (most time) I just unplug it.
why do you guys all talk about unplugging your snorkel?
surely a smooth snorkel would still allow the same airflow as the restricted intake behind the headlight? |
Originally Posted by Jkelley429
(Post 51904844)
could you show some pics of how you attached the snorkel to the airbox? Would a pvc male connector work? Maybe just drill a hole the right size, put the connector on with a lockring and glue/ silicone the shop vac hose in? Also, i was wondering if there might be a way to have an alternative way to draw air out from the stock location, and when you go wheeling block that off and draw directly from the snorkel? Only reason im asking is cause i was looking at some property the other day and the only way to get in was to go through a mudhole where the water came up to the middle of the tailgate (i have a 3'' BL). It made it through, but i dont want to take any chances of hydrolocking it in the future. Thanks
Originally Posted by reddahaydn
(Post 51911047)
great idea!
3 Attachment(s)
Guys, Don't hide your snorkels in shame. Show them off and be proud of them! jk
Attachment 201619 Attachment 201620 Attachment 201621 |
My snorkel is hidden because if I had one like that ^ a tree would rip it off first day out.
Plus, when are you ever REALLY in water that deep. |
1 Attachment(s)
My snorkel is mostly to feed good air to the SC. But somehow I manage to find some body of water to cross every Sunday.
Attachment 201626 |
1 Attachment(s)
That's why my snorkle is low.
Attachment 201622 |
Originally Posted by Bandit Runner
(Post 51912068)
http://i262.photobucket.com/albums/i...d/PICT1362.jpg http://i262.photobucket.com/albums/i...d/PICT1372.jpg http://i262.photobucket.com/albums/i...d/PICT1371.jpg |
I Need to find a way to relocate my intake also, got fiberglass. Has anyone made a snorkel that comes out of the hood? I was thinking of turning my air box so the intake faces backwards and then have a tube that connects to a snorkel just barely peeking out of the hood. I like your setup big blue!
