Dual Transfer Cases
I have a 85 extended cab truck 22re engine with an automatic trasmission i was wondering if i could still do double transfer cases i know i cant do tranfer case gear reductions so thought if possible i could do dual transfer cases if possible that is. any info would be greatly appreciated
Check with Marlin crawler or inchworm, but AFAIK you cannot do a doubler on your hydraulic 85 case.
Inchworm is the ONLY adapter for the auto tranny. You will need the adapter for about $500, plus two gear drive cases ($300 around here), a new crossmember, plus whatever options you want (lower gears, twinstick, etc).
