Bent or Straight front housing.
Hey is there any way to determine if a front housing is bent just by looking at it??? the bare housing, no knuckles, no 3rd....
If not, how would I go about confirming that it is straight?? Help !!:help: |
Well...does it look bent? Can you take a picture from the front?
I can tell ya how to bend one, does that help.
Stringline through the inside and take some measurements in the diff housings. |
"Jig bar". I took the housing to a rear end shop, they inserted this bar through the housing that seated tight against the axle seal seats, took a few measurements. All is good.
Nice.. You can do the same thing with a string line, just a little more tedious.
Glad its not bent. |
Even if it was bent, minis arent impossible to straighten. Just add patience.
