Arb compressor question
anyone who has the arb compressor know of it to leak oil? i think mine is leaking slightly. anyone know what im talking about by chance?
It shouldn't be leaking oil from the compressor since it doesn't have any. If oil is coming out of the solenoid, it's a symptom that your diff breather is clogged or you have an air leak in your lines inside the diff. Majority of them though are caused by clogged diff breather. Have you done the diff breather mod yet? You might want to check your diff breather.
George |
i have indeed done the breather mod. ill check to see if its clogged regardless.
i think im gonna need to get a new compressor now, or fix something though, cause a gasket on the compressor is letting out air..perhaps that repair kit is in order? |
i think im gonna need to get a new compressor now, or fix something though, cause a gasket on the compressor is letting out air..perhaps that repair kit is in order? George |
Where on the compressor is the air leaking out of?
I can second that ARB has the best customer service. My compressor died (a dead short in the motor) I sent it there and had a new unit by weeks end. It's possible they can fix the air leak under warranty. |
i borrowed this picture from robinhood's post about his arbs and gears.
i circle where i think its leaking..if i remember correctly. http://img50.exs.cx/img50/2322/arb.jpg |
Maybe the bolt on the other end needs to be tightend. It's always something simple.
I forgot to add this, just in case someone doesn't know. Use warm water with dish soap, paint in on the can and solenoids with the compressor powered up and where ever you see bubbles - you've got a leak. It's either going to be at the fittings, which means you either have to tighten them or take them off, re-Teflon tape the threads and tighten them back on or at the can lip which has been covered. If you have no leaks there but the compressor keeps going off & on at regular intervals - it's going to be in the line (very unlikely) or at the housing. In all my years running ARB's, I've only experienced leaks with the can and solenoid fittings. |
alright. ill try to see if i can fix the problem. thanks for the help guys.
| All times are GMT -8. The time now is 04:55 AM. |
